upgrading 2014 JBL/NAV sub
Discussion in 'Audio & Video' started by zmw, May 25, 2014.
  1. May 25, 2014 at 6:40 PM
    zmw
    zmw [OP] Well-Known Member
    SATX
    2014 TXproBAJA
    none
    So I've done a lot of reading and so far i'm not too excited by what I read. Is it possible to get a clean signal for a sub amp out of this radio somewhere? I read a lot of complaints about a grounding hiss and such when using a line converter.
    The JBL system sounds pretty good overall but needs better sub response, unfortunately the rear sub seems tied into the over all bass setting which makes the door speakers sloppy...
  2. May 28, 2014 at 7:33 AM
    Aw9d
    Aw9d That one guy
    The JBL system is pretty much as good as it will get. With low end components and a crappy amp there isn't much you can do to make it better. Most people just ditch the sub all together and go aftermarket for a sub.
