Upgrading an already upgraded radio
Discussion in 'Audio & Video' started by Jimmyparis7, Jan 2, 2023.
  1. Jan 2, 2023 at 12:37 PM
    Jimmyparis7
    Jimmyparis7 [OP] Member
    Jimmy
    North Carolina
    2005 Tacoma
    1.25” wheel spacers 2.5” strut spacer Nitto Mud Grapps 33x12.5x17
    Good evening,
    I am thinking about upgrading my car stereo since it is on its way out. I upgraded probably 5 years ago to a JVC radio. I really liked this radio and am wondering can I just slap a new JVC radio in plug and play or will I have to rewire with a new connector just like getting a new radio? If its the latter I probably wont upgrade since the truck has high mileage.
  2. Jan 2, 2023 at 12:42 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you have not modified the OEM wire harness you should find a direct plug and play unit.
  3. Jan 2, 2023 at 3:10 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    You already made a harness to go from OEM to the JVC in it currently? You want to know if the JVC plug from your current radio will fit a newer JVC headunit? Is that right? If so, you should be fine with another JVC unit. Most manufacturers don’t change the pinouts of their mid to low grade units.
  4. Jan 2, 2023 at 4:53 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    JVC from 5 years ago will probably still be the same if you’re not changing styles
    Meaning, If you are going from a basic stereo to a touch screen with dvd capability, you may not get so lucky.
    but if you already have a touchscreen (or a basic stereo) and are upgrading to the same style you have, you’ll probably be ok.
    Worst case, you cut the current harness in half and buy a pack of red butt connectors and crimp up the new harness in about 5 minutes
    ZMan2k2 likes this.
