Upgrading Audio System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ted2Paint, Apr 17, 2018.
  1. Apr 23, 2018 at 6:09 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Any link to the build?
  2. Apr 23, 2018 at 7:01 PM
    WhiskeyTaco
    WhiskeyTaco Well-Known Member
    Zach
    Denver, CO
    2011 White Tacoma Access Cab TRD Off Road
    You're bedlining the entire truck now, right?
    ssanders2211 likes this.
  3. Apr 23, 2018 at 7:52 PM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    uh...random vandels, or ex girlfriend? either way...suck!
  4. Apr 23, 2018 at 8:25 PM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Random vandals unfortunately.
    I promise you once I get it back I'll give the list of other gauges it supports!
    I just miss not having a boosted vehicle to drive! The turbo made the little 4banger so much more enjoyable!
  5. May 4, 2018 at 5:06 AM
    VanceLee
    VanceLee Well-Known Member
    2016 Toyota Tacoma TRD Sport Blazing Blue Pearl
    I have what might be a silly question but, do you need a GPS antenna adapter if your head unit doesn't have GPS built in? I have the Kenwood DDX9905s with Android Auto. Doesn't seem like you'd need the GPS antenna adapter to me but I got one anyway. Just wondering now in retrospect if you actually need it or utilize the GPS antenna.
    Thanks fellas.
  6. May 4, 2018 at 5:19 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    If the 9905 is an updated version of my 9903, the GPS is used to help boost the cell phone's gps and it's also used for the compass display on the headunit.
  7. May 9, 2018 at 5:19 PM
    VanceLee
    Thanks @kingston73 , much appreciated. I installed the adapter and DDX9905s as well as the Maestro unit this last weekend. Loving it so far.
  8. May 21, 2018 at 5:50 PM
    Camby
    Brian
    Denver
    Have that complete list on hand? Can you display oil temp & presure?
  9. May 22, 2018 at 8:44 AM
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Give me like a half hour and I'll go outside on lunch and check..I totally forgot, my apologies!
    Oil temp/pressure is not supported on our trucks, as we only have a oil pressure switch. You can always add an aftermarket oil temp/pressure gauge fairly cheaply, but the Maestro won't pick it up since it reads OBD2 data.
  10. May 22, 2018 at 12:20 PM
    dirtdigginjoe
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    @Camby and everyone else who was asking, I apologize sincerely for the delay in getting the info to you guys!
    The gauges I can currently see/select on my Maestro are:
    • Acceleration (in G's)
    • Air/Fuel (As the factory wideband sees it. Disregarding if you're forced induction, since you'd have an additional for tuning)
    • Avg fuel economy (MPG)
    • Battery voltage (Volts, duh)
    • Coolant temp (degrees F/C)
    • Engine Load (as percentage)
    • EGT (Which is really the catalyst temp, if you see the numbers you know why)
    • Instant fuel economy (MPG)
    • IAT (Intake Air Temp in degrees F/C)
    • MAF flow (lb/min)
    • RPM (self explanatory lol)
    • Throttle Position (percent)
    • Timing Advance (degrees)
    • Speedometer (MPH/KMH)
    Keep in mind the ECU of a V6 is different than my little 4-banger MT, so you may see some additional gauges that I can't (but as far as I know, you won't. At most it'd be an additional cat reading, and POSSIBLY trans temp since you can get it to read in Torque)
    The biggest benefit is having some of the basic gauges that Torque offers, right on the headunit itself. Also being able to see/clear CEL's was a nice feature.
    Each gauge is configurable for limits/warnings as well as peak numbers for scaling purposes. I never adjusted those settings so they auto-scale. It's just common knowledge what all the values should be (if you're into tuning and such)
    Camby likes this.
  11. May 25, 2018 at 12:45 PM
    Camby
    Brian
    Denver
    Thank you so much for listing this! Ive been looking all over trying to find what info can be displayed. I pulled the trigger on the ILX107 couple weeks ago; still gathering components up, so hopefully at the end of the summer I can install it et all. Very excited to be able to monitor whats going on internally with the truck, and having my 2006 updated to current technology.
    dirtdigginjoe[QUOTED] likes this.
