Upgrading door speakers with amp
Discussion in 'Audio & Video' started by Fattypack, Apr 19, 2019.
  1. Apr 19, 2019 at 12:03 AM
    Fattypack
    Fattypack [OP] Well-Known Member
    Waipahu
    2018 Cement Grey TRDORDCLB 4x4
    Looking to upgrade my audio system. What I want to do is install the focal plug and play door speakers and tweeters. I already have a sub and a dedicated amp for the subwoofer. I want to know how am I able to wire it all together. I was planning on just adding a sub and amp but I am now looking to do everything. I will be getting a Mr marv custom sub box. I will be using stock head unit entune II non jbl. I’ve been researching to forums/googling for my sub amp setup. The back storage bins will be removed and the sub box will take that space. I will be mouning my sub amp under drivers seat, not sure if I can stuff a loc and door amp under passenger seat.
    What I want to know/ what do I need?
    -Would I be able to just run a kicker key amp for doors and tweets so I could save some space while running a subwoofer and dedicated amp?
    -Would there be a better way to pump more power to my door speakers when I do upgrade it. Not looking to exceed 75 watts for my doors.
    -How do I wire all these things. I will most likely have a shop do the install.
    -Will I need to make my own harness?
    -https://www.crutchfield.com/p_1429WC1820/EFX-9-Wire-Ultra-Flex-Speaker-Wire-20-feet.html
    -Any more inputs welcomed
    What I have
    Jl10w3v3
    https://www.crutchfield.com/p_13610W3V32/JL-Audio-10W3v3-2-10-2-ohm-Component-Subwoofer.html
    Rockford prime R750
    https://www.crutchfield.com/p_575R7...-R750-1D-750W-x-1-at-1-Ohm-Car-Amplifier.html
    RFK4X amp install kit
    Toyota add an amp loc
    https://www.amazon.com/Amplifier-Interface-Vehicles-Subwoofer-Vehicles/dp/B00CQUL240
    What I want to add
    Focal front 6x9
    https://www.crutchfield.com/S-M2VjqTGYr4Q/p_091IS690TY/Focal-IS-690TOY.html
    Focal rear
    https://www.crutchfield.com/S-7kF3e3G80Z1/p_091IC165TY/Focal-IC-165-TOY.html
    Amp for door speakers
    https://www.crutchfield.com/p_575R4004D/Rockford-Fosgate-Prime-R400-4D.html
    Lc7i
    https://www.crutchfield.com/p_161LC7IB/AudioControl-LC7i-Black.html?search=lc7i&skipvs=T
    Rockford dual amp install kit
    https://www.amazon.com/Rockford-Fos...a-566519163100&psc=1&ref=&adgrpid=61293379643
    Not sure if any of this makes sense, this is my first vehicle I want to upgrade the stereo with.
    Thanks in advance,
    Jo
  2. Apr 25, 2019 at 6:14 AM
    LVLAaron
    LVLAaron Well-Known Member
    Aaron
    2018 TRD Off Road
    I'm confused. Are you having a shop do it, or are you doing it?
    hotboatrod likes this.
  3. Apr 25, 2019 at 6:19 AM
    LVLAaron
    Aaron
    2018 TRD Off Road
    I would get a kicker key amp for your mains, and this 500x1 amp for your sub.
    https://smile.amazon.com/gp/product/B00UG7ATIA/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Both of these amps have line level input so you dont need to get some cheap chinese line out converter and have more crap behind your dash.
    Order the mounting plate from taco tunes that bolts under your drivers seat. Both amps are about the same size and you'll have plenty of room for an easy install.
