Upgrading factory jbl audio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DefinitelyThor, Aug 27, 2020.
  1. Aug 27, 2020 at 9:39 AM
    DefinitelyThor
    DefinitelyThor [OP] Well-Known Member
    Utah
    2018 Black Trd Pro
    I like most others think it is almost useless and im looking to upgrade it but it seems there are some barriers in the way so i cant just toss in the oem audio kit so is there a way to get it in or another kit or otherwise to be able to get better sound out of it?
  2. Aug 27, 2020 at 10:05 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Not much options for the jbl system ... would have to do a complete system replacement .
  3. Aug 27, 2020 at 10:20 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    several threads about this in the Audio/Video section.
    Gut it and replace it all. Speakers, Amp, Sub
  4. Aug 27, 2020 at 10:44 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I plan on replacing my speakers with jbl or infinity kappa and a pioneer sub while leaving the amp etc. it is loud enough for me the sound quality is meh though.
  5. Aug 27, 2020 at 11:15 AM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    Depending on what you use for an audio service so far youtube music (hq) over bluetooth hands down sounds the best. Better than carplay over wired or anything else on bluetooth. Its not even close. I prefer a flat sound with decent bass and as of now have no reason to upgrade. Your results may vary but worth a shot.
  6. Aug 27, 2020 at 11:16 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    so if i want to put in the kit from oem audio plus the only thing i would need to change is the factory amp, and could i just switch it for an amp from another taco that doesn't have the premium audio package and have it function just as a normal taco with said kit?
  7. Aug 27, 2020 at 11:19 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    ive gotten mine decant through spotify and some eq stuff, the problem is that it starts to get quieter after about 30 min of listening to it very loud, and it doesnt get as loud as i would like it and i have a friend who has the full kit from oem audio plus with the dual subs and its just a whole different experience that is 1000% better imo and i would like to do the same
  8. Aug 27, 2020 at 11:19 AM
    Hatfieco05
    Portland, OR
    The oem audio kit does sound really good. Not sure why yours gets quieter I havent had that issue?
  9. Aug 27, 2020 at 11:22 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    no clue but it pisses me off, it starts out just a bit quieter than i would like but after about 30 min it is significantly quieter and the sub shuts off or at least i think(so ive probably broken some speakers) but it gets better if i turn it down to 10 or so for like 10 min and turn it back up it gets fixed
  10. Aug 27, 2020 at 12:19 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    You can’t put the OEM kit in with the JBL system.
    short of a LOT of wiring work (and a new non-JBL head unit) you’re not getting the OEM kit in that truck unfortunately
  11. Aug 27, 2020 at 12:22 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    i should have phrased it better, if i change the stock amp to the stock amp from a non jbl audio truck could i then install the oem audio kit since i would the have the speakers and sub from that and an amp changed out to a standard amp?
  12. Aug 27, 2020 at 12:33 PM
    CoTacos
    CoTacos Well-Known Member
    Steven
    Denver, CO
    2019 White Tacoma TRD OR DCSB Prem. Tech
    DiamondBack SE RCI Armor Max Modular 14 Rack Collapsing Suspension
    You could just swap the headunit for something that pumps out more power and has android auto/car play and EQ ability. Sounds noticeably better, not amazing by any means, but it's now exactly what I expect out of a factory set up. The stock headunit is a bit lacking.
  13. Aug 27, 2020 at 12:36 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    i like a lot of the other functions of the head unit like the bread crumbs that it can leave so i don't get lost on trails and such, im really just hoping to change out the speakers and add an amp(there paper cones so im probably already breaking them down)
    CoTacos[QUOTED] likes this.
  14. Aug 27, 2020 at 12:40 PM
    CoTacos
    Steven
    Denver, CO
    That's fair! I didn't know the stock headunit could do that. May be worth a dedicated nav solution and taking the easy way out for audio?
  15. Aug 27, 2020 at 12:46 PM
    DJSatan
    DJSatan Well-Known Member
    Auburn, WA
    2020 AG PRO, 17 BLUE LE SOLD, 16 MM OR SOLD
    you can keep the stock HU just have to get a new signal processor, amp, speakers, and decide if you want to upgrade the sub as well
  16. Aug 27, 2020 at 12:53 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    what im asking is if i get the stock signal processor and amp from a totaled say offroad would i be able to install speakers like its a normal speaker system?
  17. Aug 27, 2020 at 1:01 PM
    DJSatan
    Auburn, WA
    the Head Unit is the defining factor
  18. Aug 27, 2020 at 1:04 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    No.
    There is no amp on the non-JBL. The head unit powers everything. And al of the wiring is different. Different connectors, different signals, different everything.
    DJSatan likes this.
  19. Aug 27, 2020 at 4:28 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    ahh, so i would have to do all the wiring and stuff?
  20. Aug 27, 2020 at 5:13 PM
    kadamik
    kadamik Active Member
    I have a 2020 JBL system and I upgraded what I could in stages.
    1. I used Nirco sound damping on the doors, in my opinion this made the most difference.
    a. I used Nirco on the back of the truck
    b. I used Nirco around the plastic sub enclosure and on the inside of the enclosure.
    2. I replaced the front and rear speakers with JBL 2.3 ohm speakers.
    3. The second biggest difference was replacing the sub with the dual 4 ohm kicker sub. Then you wire the sub for a single 2 ohm input. Then you bridge the JBL amp. You can tell it increases the watts a little you can tell a difference.
    You might have to modify the base box for the kicker sub it is a little deeper, I think I had to trim down the internal fins inside the enclosure.
    If you don't want to do that then you can use the Pioneer shallow mount sub, it fits perfect even the screw holds line up. if you go with the pioneer then you have to keep it dual 2 ohms so you can't bridge the JBL amp.
    The kicker sounds louder and has lower bass. (but that might be because it was bridged.
    That was stage 1. It sounded a lot better than factory
    Stage 2 was getting an audio control amp 300.1 with bass knob and then hooking up to a JL sub. That made the biggest difference.
    Stage 3 is getting an addition amp to power the tweeter/6x9 and the 6.5s
    Stage 1 and 2 sounds great to me so I am not going to upgrade to stage 3 yet.
    Potamus, Flying-Taco and Hooper89 like this.
