Upgrading performance with no lift?
Discussion in 'Suspension' started by TCprerunner, Jul 27, 2013.
  1. Jul 27, 2013 at 10:30 PM
    TCprerunner
    TCprerunner [OP] Well-Known Member
    I have been searching for awhile and have not came across much anyways other then a coil over. What options are there for upgrading off road performance more speed oriented then crawling? I'm set on a mid travel still but It's over kill for what I need it/want it for and I am not wanting any lift and don't really need the extra travel I just want better off road performance.. Mostly high speed fire road type stuff with some pretty deep wash outa and ruts 6-12"s in some places .. Just brain storming while I don't have the money to buy anything
  2. Jul 27, 2013 at 10:36 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Smaller tires?
  3. Jul 27, 2013 at 10:38 PM
    TCprerunner
    ? Not sure if serious?
  4. Jul 27, 2013 at 10:40 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    More travel = better performance. Only other option is coil overs. YOu arent really going to get high speed performance with no added travel or coil overs.
  5. Jul 27, 2013 at 10:47 PM
    TCprerunner
    Like I said I am still planning on going mid travel just brain storming while waiting around with no money.. I mean there has to be better performing struts, springs and leafs that maintain factory ride hight right? I'm not saying for going out and hitting dunes or desert runs.. Anyways I guess my confusion is where the performance comes from? On mid travel, I know the big gains are travel but you only gain what, 1" of droop? I know it is a big deal but why does so little do so much? If there is a suspension and how it works for dummy's that explains all this please by all means point me in the right direction lol
    I am just trying to understand why I need a mid travel rather then just " because the cool kids are doing it "
  6. Jul 27, 2013 at 10:57 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    MT you gain no travel unless you go to an aftermarket UCA. And all the MT guys are running coil overs.
    A normal shock works by fluid and compressed gas. and the fluid is ported thru a hole at a specific rate. Add a Coil to that and now you have all those working together. Depending on your spring rate. The more travel just means your shock can work for you longer. In some applications you can tune at different strokes of your shock. Also shock fade is something to consider. With a larger shock or coil over, or especially with an external reservoir, you get more oil. Which allows your shock to remain cooler when being worked hard.
    Don't waste your money on anything else, just save for MT. You can run MT at no lift if you so desire, but at that point you might as well adjust the c/o to give you some ground clearance.
  7. Jul 27, 2013 at 10:57 PM
    worthywads
    You want speed you say, no need for clearance, smaller tires are like a regear.
  8. Jul 27, 2013 at 10:59 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Long Travel
  9. Jul 28, 2013 at 5:57 AM
    TCprerunner
    Im going to be running the tc uca, icon 2.5 extended travels up front.. I guess I am not wording things right I am not trying to be talked in or out of mid travel just wondering what kind of upgrades are out there for someone who wanted to stay away from coil overs..
    I think you are reading the wrong thread... Lol pretty sure re gearing tire size ect have nothing to do with suspention performance...
    Have 10k I can have?
