Upgrading Rough Country 3" spacer kit?
Discussion in 'Suspension' started by DC2010, Mar 22, 2017.
  1. Mar 22, 2017 at 3:26 PM
    DC2010
    DC2010 [OP] Active Member
    David
    Westfield,MA
    2010 Tacoma
    Billsteind 5100's 887 coils JBA UCA custom Morimoto HID projection retrofits by C&W Custom as well as Morimoto custom fogs and LED Tails and their brake light. 32" in bumper light bar by Rough Country. Cali Raised ditch mount pods both regular and amber. Dick Cepek DC2 wheels with Falken Wild Peak 32" tires. Afe exhaust and cold air intake. Tinted front side windows. Seat covers. AJT shifter knob. Blacked out badges. American Toneau bed cover.
    I am running a rough country 3" spacer kit right now and I want to upgrade without spending a fortune. Any thoughts on ways to go? 2010 4x4 4.0 access cab.
  2. Mar 22, 2017 at 3:57 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    The usual suspects - Billie 5100's or OME shocks and the appropriate coils.
    kevinlambchops and DC2010[OP] like this.
  3. Mar 22, 2017 at 6:17 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Define a "fortune."
    DC2010[OP] likes this.
  4. Mar 22, 2017 at 9:05 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    I'm not even sure anymore lol. I used to drop a couple grand without hesitation. But I'm getting old so I'd like to spend as little as I have too. Around 700.00 or 800.00 I'd be ok with.
  5. Mar 22, 2017 at 9:07 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    Besides "I'm doing this for the kids safety" is only going to fly so many times!
    diabetiktaco likes this.
  6. Mar 22, 2017 at 9:08 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I'd second bilstein 5100s with good springs. Are you installing them yourself?
  7. Mar 22, 2017 at 9:12 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    Yeah I will be. At a friends garage.
  8. Mar 22, 2017 at 9:16 PM
    nDub
    Lead Free Gasoline
    Bilstein 6112!
    But that'll blow most of your $700
    Check out headstrong or allpro off road websites. Or toytec or Amazon or the list under venders on this forum.
    I'm partial to Allpro. If you buy a kit they usually include all the things you'll need.
    Usually if you call them they'll help you find exactly what you need/want.
  9. Mar 22, 2017 at 10:40 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    Thanks I think if I went that way I could avoid UCA's and leave the block in the in the back. Thanks.
  10. Mar 22, 2017 at 10:53 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    With the 6112 how does the settings work? Typically with the 5100 the spring provid the lift and you set them at 0. Do you need to set them at 5 for 2.5"?
  11. Mar 23, 2017 at 6:21 AM
    nDub
    Lead Free Gasoline
    They're adjustable but only up to 2.5"
    Might not be enough for you, coming from 3".
  12. Mar 23, 2017 at 9:58 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    @DC2010 any lift setup over about 2.25" is going to run into a Low Caster situation. UCAs are not required, but will allow you to bring the alignment numbers back into spec.
    The 6112s come with their own coils due to the shocks being so large in diameter. Otherwise yes they work just like the 5100s as far as lifting goes. You choose a setting during the assembly process for the desired lift height.
    nDub and DC2010[OP] like this.
  13. Mar 23, 2017 at 10:54 AM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    Dan,
    I'm not sure the RC is a true 3" of lift. I'm beginning to think the Billie will give me actuallly more space. Maybe I'm wrong.
    And thanks for the 6112 information.
  14. Mar 23, 2017 at 1:09 PM
    Sugar Silva
    Dave
    San Diego, CA
    You would be very happy with the 6112s. I have them and have been impressed with their performance on and off road. If you were only going to replace the front shocks then I would suggest you give them a look. If you wanted to replace all four, I would look at the 5100s all the way around due to the budget
  15. Mar 23, 2017 at 1:16 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    Thanks. I'm thinking the 5100's. Maybe with 887 springs. I am trying to figure out if UCA's are a must.
  16. Mar 23, 2017 at 1:34 PM
    nDub
    Lead Free Gasoline
    Keep us updated! I'm in for a lift once I wear out my current tires.
  17. Mar 23, 2017 at 1:37 PM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    Will do
  18. Mar 24, 2017 at 9:06 AM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    I went with the 5100's and 2887 springs From Head Strong.
    nDub and Sugar Silva like this.
  19. Mar 25, 2017 at 10:41 AM
    DC2010
    David
    Westfield,MA
    2010 Tacoma
    I also ended up pulling the trigger on JBA UCA's after reading all the post on alighnment issues. Now I hope my 2" block will be enough after I do the springs and shocks.
    Masshole_And_His_Taco and nDub like this.
  20. Mar 25, 2017 at 2:31 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    That block in the back is going to ruin your springs!! At the very least, do an Add A Leaf!!!!
    SocalOC likes this.
