Upgrading Suspension
Discussion in 'Suspension' started by Rtylenda, Jun 30, 2022.
  1. Jun 30, 2022 at 4:45 AM
    Rtylenda
    Rtylenda [OP] New Member
    Rusty
    2019 Tacoma off road
    I am ready to upgrade the suspension on my 2019 Tacoma OR DCSB, recovery equipment and drawer system in the bed and a fiberglass cap installed full time.
    This is my material list. I am going to use Bilstein materials, Bilstein 6112 Strut and Spring + Rear B8 5100 shocks, also going to install Icon Multi-rate RXT Leaf Spring Kit w/ 1.875-2.625" lift, using an 8" U-bolt kit.
    Am I missing anything? I currently have a set of Sumo Springs installed but I hope I won't need them after installing the RTX Leaf Spring kit. I do have the factory bump stops but don't know if I need to order spacers for their re-install. Will I need rear bump stop spacers?
    Truck is a daily driver, with under a dozen overlanding trips per year, East coast.
    Any guidance is appreciated.
  2. Jun 30, 2022 at 6:07 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I recommend ecgs bushing for the front driver needle bearing in the front diff and timbrem bumps tops and ubolt flip kit for the rear
  3. Jun 30, 2022 at 7:05 PM
    circlecitymedic
    circlecitymedic Well-Known Member
    I've been running the same Bilstein's for about 1.5 years now and they've performed great and were pretty easy to install. Might take a couple of height adjustments in the front to get the lift height you want dialed in, but that's not really a big deal. I'm at about 1.5" up front and haven't needed an ecg bushing.
    One thing to consider with the leaf setup is that your truck has a lot of weight in the bed with the cap and the drawer, so if it's in the budget you might want to consider getting a whole replacement leaf pack designed for more weight. I'm running the basic ICON 1.5" add a leaf in the rear, and with probably less weight in the back than your truck (I've only got a bed rack and RTT), and I barely have any lift in the rear at all.
