Upgrading Tire Size on Stock Suspension
Discussion in 'Wheels & Tires' started by Drogers, Apr 5, 2011.
  1. Apr 5, 2011 at 6:31 PM
    Drogers
    Drogers [OP] Well-Known Member
    Derek
    Sayville, NY
    2010 Reg Cab 4X4 5sp manual
    Leer 100XR Topper, Re-wired interior dome light, Shaved front mud flaps, Rebadged flat black, Avid offroad light/bull bar, Yellow OEM Fog Light Mod, 265/75R16 Nitto Terra Grapplers, stock 16 steelies painted flat black, K&N air filter
    I am currently running 245/75R16 on my stock wheels. I understand that I can run 265/75R16 on my vehicle which has stock components.
    1) I am about to pull the trigger on some Terra Grapplers and want to be sure that there will be no modifications necessary with running this slightly larger tire? No spacers involved, shaving, etc?
    2) I also understand that I might lose some power, take-off, acceleration and mpg. I am hoping since this is an all terrain type of tire that the above will be minimal. There were suggestions that I can switch up my air intake and exhaust to kind of compensate for any losses that I may experience. I know that I can regear but this seems to be the more expensive option, but perhaps more sensible.
    If anyone can chime in on these two questions with your experience that'd be great!
    Thanks in advance.
  2. Apr 5, 2011 at 8:46 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    1. You'll have no issues
    2. Any loss will be fairly minimal when only going up one size like that. Intakes and exhausts don't really help the mpg on these trucks at all. The stock intake is already drawing cold air from the fender well.
  3. Apr 11, 2011 at 2:02 PM
    freezb
    freezb Active Member
    montreal
    tacoma trd 2011
    roof rack toyota side step toyota
    265-75-16 or 265-70-17 no problem with the gear??
  4. Apr 11, 2011 at 2:04 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    dont bother regearing just going up one size, if you went to 35s then that would be a different story
