upgrading to a taller coil
Discussion in 'Suspension' started by Boogyman, Mar 27, 2015.
  1. Mar 28, 2015 at 5:44 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
  2. Mar 28, 2015 at 5:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. Mar 28, 2015 at 5:46 PM
    Butterless Toast
    Butterless Toast Well-Known Member
    NKY
    2015 Tacoma TRD Sport
    Yes with a 5mm height difference. 884s are designed for 4runners and FJs, 885s are for tacomas. 886s are for tacomas with added weight such as a steel bumper and to acheive the same height as an 885. If only taller springs were required than OME would reccomend 887s for added weight but they dont...
  4. Mar 28, 2015 at 5:47 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    It all depends amigo, a tube bumper no, an aluminum 75lb bumper no, it all depends on what ride height or stance you are trying to maintain as you add weight. Pre loading a spring to compensate for extra weight does not let that spring ride as comfy as it could. A heavier spring not pre loaded can ride smoother than a pre loaded lighter spring.
  5. Mar 28, 2015 at 6:01 PM
    Boogyman
    Boogyman [OP] Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    I'm running a steel plate with full hoops and its brought my ride height down more than I'd like especially when I'm needing a full 3in of lift soon.
  6. Mar 29, 2015 at 5:06 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    i just contacted DSM so hopefully well find out. i linked this thread in my email so maybe they'll respond here
  7. Mar 30, 2015 at 11:58 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    You can't do it. The shocks Arnt made for taller coils
  8. Mar 30, 2015 at 3:19 PM
    tacogringo
    tacogringo Member
    Green Mountains
    13 reg cab taco
    bilstein 5100s front and back, front at 1.75". Wheelers 1.5" single add a leaf. afe pro dry filter. secondary filter delete. Toytec swaybar relocate. tailgate secure mod
    what did they recommend? I was thinking if it was possible to change the studs on those to longer ones, maybe you could put some 1/2" top plates or something. But certainly don't buy anything off anything I say. I am only throwing out ideas to get conversations going that might help with your research..
  9. Mar 30, 2015 at 3:26 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    They said to just do the 650s if i haven't gone over 175-200lbs of added weight. I was thinking of going with the 650 and doing a .25in spacer on one side and .5 on the other so I'm not dicking with my adjustments to counteract taco lean and give me just a little more height
