Upgrading UCA's on PRO worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jonmartin, May 3, 2017.
  1. May 3, 2017 at 3:38 PM
    jonmartin
    jonmartin [OP] Well-Known Member
    Jonathan
    818
    CEMENT 17' TRD PRO 6MT
    TRD CAI Intake, Audison Bit ONE HD,Audison AV 5.1k HD Amp, Focal/Voce Speakers , Morimoto HID,Bakflip MX4..More to come
    Would there be any benefit on upgrading the UCA's or other suspension bits (ex: leafs) OTHER then whats included with the TRD PRO suspension package? I like my the stock suspension on the PRO It works well enough for me so I don't really want to change the suspension out but I don't mind adding tweaks if it well improve performance/capability on whats there, And maybe down the line if I get bored I'll do a full suspension upgrade. Also if I did feel the urge for more lift that would require all new shocks etc correct?
  2. May 3, 2017 at 3:51 PM
    su.b.rat
    su.b.rat broken truck
    i just bought a set of UCA's in the last group buy, and i'm installing them and realigning next Thursday on my Pro, which is mostly stock (added Hellwig rear sway bar & sumosprings as well as wheels/tires) with a stock tire size. why? because i can dial in more caster. and that, for me, is worth paying the price. normally limited to around +3deg caster give or take. i'm hoping to get at least +4 if not more out of them.
    jonmartin[OP] likes this.
  3. May 3, 2017 at 5:35 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    What is wrong with Caster on a stock TRD PRO? I must know.
    Ch78 and dYL0n like this.
  4. May 3, 2017 at 6:08 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    4 to 5 deg caster is great for large tires and makes it far more stable on road, but will also add more ware and tare to steering components. If you have a "twitchy" lifted vehicle that's prone to steering shake it's the fix you should try before a steering stabilizer. It's why I don't get people trying to get less caster, just to fit bigger tires on a tacoma.
    jberry813 likes this.
  5. May 3, 2017 at 6:11 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Great info except the steering stabilizer bit. Tacomas have a rack and pinion steering which does the dampening. Adding a steering stabilizer will actually fight the rack.
    Nothing...until you add bigger tires.
    rmepilot likes this.
  6. May 3, 2017 at 6:44 PM
    su.b.rat
    there's nothing at all wrong with it. it's fit for purpose. but i'm primarily a highway driver, and i have my truck kinda setup for that. so adding more caster works right into my direction. the idea is the less caster you have, the more the front end weight sits right on top of the wheels, so it makes things very responsive and easy to drive around town. adding caster moves the front end's weight a bit back toward the driver, so it makes for a more stable steering and front end feel. but it's not as quick to respond due to being a tick slower in weight shifting with higher caster. as always though, these things are interdependent and it's not as black/white as described. many open wheel race cars with extremely quick front ends have high caster settings, for example. it's more simple for our trucks though.
  7. May 3, 2017 at 6:47 PM
    su.b.rat
    thanks, i'm gonna make a note of that.
  8. May 3, 2017 at 6:57 PM
    smitty99
    Scottsdale
    I Just didn't see a mention of tires or other suspension mods (lift)
  9. May 3, 2017 at 7:03 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Didn't you buy a pro because it's the ultimate truck ever? If you wanted to upgrade your truck with aftermarket stuff that's better than fox, buy a TRDOR.
    airborndad likes this.
  10. May 3, 2017 at 7:08 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    There is absolutely nothing wrong with 3* caster. Anything more is a waste and won't change anything.
    There is absolutely ZERO benefit to running aftermarket UCAS on a stock rig other than the "look at my control arms bro" benefit.
    They give you more caster but only needed if lifted. They are lower profile so easier to clear 33"+ tire sizes. They will not max out at full droop when running extended lift coils so the ball joints last longer. Again only benefits of lifted.
  11. May 3, 2017 at 7:10 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Get UCAs when you lift, otherwise leave them stock. </thread>
  12. May 3, 2017 at 9:52 PM
    su.b.rat
    are you saying you cannot tell the difference in how it drives when the caster is raised beyond 3 degrees? if so, that's fine but speak for yourself. I'm installing my uca's for the added caster degree or two because it will make a big difference to every moment the wheel is in my hands. true, but I'm also a driving and car setup freak.
  13. May 4, 2017 at 4:43 AM
    JayRolla
    Colorado Springs
    I've tested 1.5, 3, 4, and 5.5* I my SPCs. I found pretty much zero change above 3*. If anything all it did was make steering a lot stiffer when turning.
    Also running such high caster can push the tire into the firewall causing tie clearance issues when fully stuffing the front tires.
    Aftermarket UCAS give your more caster at the cost of firewall clearance.
