uphill boat towing with 2.7L 4cyl manual
Discussion in 'Towing' started by towmyboat, Jan 10, 2010.
  1. Jan 10, 2010 at 6:55 AM
    towmyboat
    towmyboat [OP] Member
    Looking to buy a 2.7L 4cyl 4x4 stick (Oh, it has 234,000 miles on it!!) strictly to tow my ski boat which weighs 3,300 lbs with the trailer. There is the boat ramp (normal grade I guess), flat for about 20 feet then an uphill steep grade for about 40 feet. I'm concerned about this hill. Should I consider a different vehicle? The one for sale has large big tread tires. Sorry if I missed this posting somewhere else. I searched a good bit.
    Thanks for any help!
  2. Jan 10, 2010 at 7:02 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    your right at towing capacity, but put it in 4wd and you'll have no problems.
  3. Jan 10, 2010 at 7:02 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    You should be fine going up that 40 foot slope in 4 Wheel Low Range.
  4. Jan 10, 2010 at 7:05 AM
    towmyboat
    Really? I'm just a smidge under top capacity of 3,500 lbs and the hill is steep. Not ridiculously steep but steep enough to concern me. Got a short trip after the one hill.
  5. Jan 10, 2010 at 7:07 AM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    I have a 2.7L 4x4 5 speed. Although I don't have a boat so I can't say from experience, I would assume it would be just fine. If it was 2wd I would say you might have some issues with your rear tires spinning if they are on a wet hill, but throwing it into 4hi or 4lo would solve that issue.
  6. Jan 10, 2010 at 7:34 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I believe that when they (Toyota) figure towing capacity, they take into account inclines that would be encountered while towing.
  7. Jan 10, 2010 at 8:09 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    In 4lo you will probably be able to almost idle out of the boat ramp up the hill.
    There will be no horsepower issue due to the low gearing. It is only in the higher gears that you start to see issues with the 4cyl on hills.
  8. Jan 10, 2010 at 8:31 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    yeah it shouldn't be an issue at all...i pulled 4000+lb trucks outta the mud with my old '88 4x4 using 4lo...and the new 4cyl has more power than that one did
  9. Jan 14, 2010 at 7:03 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I had an 09 4 cyl. It will not be an issue.
