Upper and Lower Ball Joints?? WTF?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prozac, Nov 30, 2012.
  1. Nov 30, 2012 at 3:59 PM
    prozac
    prozac [OP] Well-Known Member
    Zach
    SoCal
    2006 TRD Sport Double Cab Long Bed 4.0L v6
    Hey guys,
    so forgive my stupidity here but I just got my Taco back from getting new wheels put on and the mechanic who worked on it comes out to tell me that I really need new upper and lower ball joints and that he'd be much more comfortable if I just left it there for him to do because he did not think it was safe to drive.
    Even after his urging I insisted on taking it home but mainly because I don't know what the hell these are.
    And I probably would have just said yes if he was not saying it would take 4.6 hours of labor for the upper ball joints and 4.8 hours of labor for the lower ball joints (all billed at $75 an hour)
    So what does this mean exactly? anyone care to explain ball joints and why that makes my truck unsafe to drive?
    Is this labor price reasonable?
    Is this something I can do myself?
    Thanks in advance for the help guys, just don't want to get screwed :/
    Zach
  2. Nov 30, 2012 at 4:05 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    he wanted to charge 10 hours of labor to change upp and lower ball joints? thats pretty steep. im a noob when it comes to working on trucks and i could do both my ball joints in less than 5 hours.
    the ball joint is what connects your upper control arm to the spindle. and the spindle to the lower control arm. do you know what those are? sorry im not sure how much you know.
  3. Nov 30, 2012 at 4:08 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Not sure if that is just something they program in to a computer and get billing, but I could do all 4 ball joints in a little over an hour of work. So I would say he is over charging. Price out Moog BJ's and find someone to install for you.
  4. Nov 30, 2012 at 4:08 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    upper/lower ball joints are a real thing, but i agree with 97yota4wd... that does seem a bit steep for labor. they can be a bear to remove/replace, depending on how rusty things are under there, but a 4 lb. maul and a 4wd ball joint press (rented from o'reilly/autozone/etc) can get the job done in a fair amount of time.
  5. Nov 30, 2012 at 4:13 PM
    97yota4wd
    Eric
    Mesa, AZ
    well with a brand new truck i guess i could do it in a couple hours. my truck on the other hand........ lol
  6. Nov 30, 2012 at 5:37 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    You just need the right amount of lube. I think this statement holds true for just about everything in life.
  7. Nov 30, 2012 at 8:14 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    I attached some PDF's for you if you decide on doing the Ball joints yourself Hope this helps a little.
    Sittingbull2
  8. Nov 30, 2012 at 8:18 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
    here it is step by step.
  9. Nov 30, 2012 at 8:55 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    The moogs run about $50 a piece for lowers and 30 for the uppers so your looking at just say $200 for parts and uppers can be quite a bitch if you don't have the right tools, took me abt 30 mins per are for uppers with correct tools and probably 30-45 for boh lowers so I think at most he should only charge around 4hrs total! I actually looked it up one time and think it called for abt 2.2 hrs or so for uppers and same for lowers... You can deffinatly handle the lowers your self, really simple but if you don't want to rent or know how I use the ball joint press tool then I'd have someone do the uppers for you but it's do-able! Goodluck!
  10. Nov 30, 2012 at 9:15 PM
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    I would just take my business to another shop. Not worth it to do the repairs yourself unless you have the time, knowledge, and tools.
  11. Nov 30, 2012 at 11:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Hey OP, you are a 6 lug and not a 5 lug, right. All the answers so far have assumed 6 lug but I can't really tell from your info.
    I've not done the lowers myself but have seen it done, not too dificult compared to the uppers.
    The upper BJ is a press fit into the spindle. You must have the correct bj press to swap it out. Either that or remove the spindle and have a shop press out the old ones and press in the new ones.
  12. Dec 1, 2012 at 8:41 AM
    prozac
    Zach
    SoCal
    I am a six lug ... 97 4wd manual locking hubs
