UPPER AND LOWER CONTROL ARM BUSHING WORN TO HELL AT 121K
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Oct 8, 2015.
  1. Oct 8, 2015 at 5:54 PM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    09 base extracab 2.7 2wd 121k. Im replacing said bushings and want to know if this mileage is typical or premature. Admitedly I have in the past driven on some shity dirt roads to the jobsite (dutycalls). Still Id like some feedback on others mileage when replacing control arm bushings.
  2. Oct 8, 2015 at 6:04 PM
    Pigpen
    Dan
    Northwest Montana
    My LCA bushings were fucked at 50K. Haven't messed with them yet, though.
  3. Oct 8, 2015 at 6:07 PM
    zjeep123
    zjeep123 Well-Known Member
    NJ
    '15 TRD OR MGM
    is there a way to grease LCA bushing bolts a a part of the regular maintenance without a need for the alignment every time?
