Upper and Lower Control Arms
Discussion in '1st Gen. Tacomas (1995-2004)' started by UCPA111, Oct 9, 2021.
  1. Oct 9, 2021 at 5:49 AM
    UCPA111
    UCPA111 [OP] Active Member
    shawn
    2002 Tacoma
    Hi all. I've been doing some searching and see some forums with older info. On my 2002 xtra cab, 4wd TRD model (3.4L with 5 speed) I am continuing to restore and looking at new LCAs and UCAs. I am replacing shocks and coils with 5100 bisteins with OME 2880. Thinking of biting the bullet for new control arms as well.
    Could go stock Toyota. Have read good things. As I am not lifting the truck (not more than an inch) it seems a logical way to go. Seem pricey for what they are but read they are good quality.
    Don't want a low quality control arm. I am 90% on road and then some gas well trails and such (no crazy off roading, but will drive into fields or trails when hunting or such). But, I may take a run out to Colorado to hit Black Bear Pass and some trails.
    I figure any set will get fluid filmed to provide some corrosion resistance.
    Not really wanting to purchase billet sets.
    I am in NW PA and we see lots of salt in the winter. Thinking a protected/covered ball joint is important.
    Thoughts? Thanks in advance.
  2. Oct 9, 2021 at 7:05 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Are your control arms in such bad shape they can`t be refurbished or is the New Control Arms just a labor (time) saving measure .
    Plan to replace the Cam Bolt hardware I needed to cut my old cam bolts out and install new ones to be able to adjust things.
    whatstcp likes this.
  3. Oct 9, 2021 at 9:34 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    That’s what I did. Been happy with it.
  4. Oct 9, 2021 at 10:30 AM
    UCPA111
    shawn
    2002 Tacoma
    Thanks guys. It was more of a time saving thing. Already having the vehicle on a lift and replacing steering - inner and outer tie rods. Wanted to future proof with new. No issues with ball joints at this point.
    If I was to replace...thoughts?
  5. Oct 9, 2021 at 12:16 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    How much are they? Seems like a total waste of money to myself and seemingly everyone else in this thread. It's just a cast piece of metal. Not exactly a ton of failure points to worry about. Replace the bushings and ball joints... these are designed to fail over time unlike the indestructible control arms.
  6. Oct 9, 2021 at 1:05 PM
    Bivouac
    I would look for used ones from someone doing a solid axle swap install new bushings and Toyota Ball joints Keep yours as spares or sell them
  7. Oct 9, 2021 at 1:15 PM
    UCPA111
    shawn
    2002 Tacoma
    Thanks. Would you go with Toyota bushings and ball joints or aftermarket?
  8. Oct 9, 2021 at 1:16 PM
    Bivouac
    Toyota Ball Joints !
    UCPA111[QUOTED][OP] likes this.
  9. Oct 9, 2021 at 1:20 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Ehh. If you plan to keep the truck a long time, new OEM LCA's are not a bad investment. Yeah you could buy new bushings only, but then the labor costs are higher to install.
    UCA if you are going to spend money, might as well upgrade to an aftermarket UCA like JBA, SPC, Etc.
  10. Oct 9, 2021 at 4:44 PM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    I went with OEM LCAs on mine and have been very happy with them on my mildly lifted truck.
    Make sure to grease everything when you're in there, I replaced mine because my alignment cams were seized.
  11. Oct 9, 2021 at 6:09 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Here's a little soapbox I did a while back on the balljoints.
    https://www.tacomaworld.com/threads...-2004-4x4-doublecab-trd.622208/#post-21222495
    If you've done as much reading on the ball joint issue as the control arms, you'd understand these are really the main weakness of the 1st gen Tacomas, and NEED to be closely cared for. As I say in the soapbox, get the best you can afford, I've been happy with 555's for reasons I explain in the link.
    When in doubt, replace them. Don't wait for them to fail, as it is generally catastrophic.
