Upper Ball Joint Blues
Discussion in '1st Gen. Tacomas (1995-2004)' started by japedu, Jul 13, 2022.
  1. Jul 13, 2022 at 4:13 PM
    japedu
    japedu [OP] Well-Known Member
    23221
    98 limited 5vz-fe 5spd w/ locker
    i'm totally perplexed. i'm installing new OEM upper ball joints (43310-39016), but they don't fit in the top of the knuckle. toyota and the internet says i have the correct UBJs.
    i measured the OD of both new UBJs and the ID of both of my knuckles. both UBJ's were the same size and both knuckles were the same size, but there was a .010" interference between the respective parts. in my experience, that's way too much. should be more like .003". the ball joints i pressed out were .005" smaller than the new ones, but not sure if life in the knuckle would impact them. i assume not, but maybe?
    despite my opinion about the appropriate amount of interference, i actually only realized the issue after attempting to press one in. it wasn't going smoothly, so i stopped and pushed it back out. the metal on the UBJ was noticeably sheared / deformed by the knuckle around the entire perimeter. so it's not that it wasn't centered or crooked or something.
    i have no clue what to do other than attempt to machine down the UBJs. but that seems kinda nuts to me. so hoping for a little TW wisdom!
  2. Jul 13, 2022 at 4:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're not fun to press in and out usually. It's a tight fit. You could freeze em in the freezer overnight and they may shrink a thou or two. Likewise with heating the spindle a bit to enlarge it
    Wulf likes this.
  3. Jul 13, 2022 at 4:23 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Where did you source the parts from? Lots of fake Toyota parts on Amazon/eBay
    What are you using to press them in?
  4. Jul 13, 2022 at 4:32 PM
    japedu
    23221
    good thought. i was wondering about how much the freezing would help, but i was hoping not to heat the knuckle because i wanted to apply some anti-seize. might be my only option though.
  5. Jul 13, 2022 at 4:33 PM
    japedu
    23221
    i got the parts directly from mcgeorge toyota. using a 20 ton press.
    Wulf[QUOTED] likes this.
  6. Jul 16, 2022 at 8:22 AM
    japedu
    23221
    a couple small updates:
    - i bought some UBJs from Napa made by 555, and they are the same OD as the new toyota UBJs. so no help there.
    - i did the math for freezing and heating the parts, and it would reduce the interference by about .006". that would would bring it within range, but once the temps equalize the outward pressure on the knuckle would be considerable. without knowing exactly what that knuckle is made from, the potential for failure would be beyond my comfort level.
    it probably sounds like i'm being too nerdy about this, but the simple fact is that UBJ will not press in without damaging the parts. so that just can't be right.
    anyone have some new toyota UBJs that match my originals with an OD of about 1.701"?
  7. Jul 16, 2022 at 9:36 AM
    Speedytech7
    The knuckles are forged steel
  8. Jul 16, 2022 at 9:50 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Press them in and send it.
  9. Jul 16, 2022 at 11:31 AM
    Sang15
    Sang15 Active Member
    Andy
    1998 blue taco
    Stock
    mcgeorge toyota has reasonable prices
  10. Dec 14, 2024 at 3:13 PM
    johnfregan99
    johnfregan99 Member
    Dented 1998 Tacoma 3.4l 5-SPD 4x4
    I am currently having the exact same problem with my 1998 tacoma 4WD with locking hubs. Did freezing work for you?
  11. Dec 15, 2024 at 7:17 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I used a big pneumatic impact gun on the ball joint press. Didn't go in straight at first, but it straightened out after using sufficient force.
  12. Jan 3, 2025 at 5:41 AM
    japedu
    23221
    i forgot to follow up after my last post: essentially, just press them in and don't worry about. i didn't freeze or heat anything. i found a thin metal ring jammed between UBJ and the knuckle, and realized that the knuckle shaved the UBJ down when it was pressed in by the factory. i replaced the passenger and driver side UBJ, and found the same ring on each side. so i pressed them in, and that same thin metal ring was created each time.
    Clearwater Bill and Kiloyard like this.
