Upper Ball Joint removal on 2012 tacoma..... looking for info and pics..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco_Rama12, Mar 29, 2019.
  1. Mar 29, 2019 at 8:59 PM
    Taco_Rama12
    Taco_Rama12 [OP] Active Member
    Martin
    Portland, OR
    2012 Dlb-Cab TRD Taco
    5100's all around, with upgraded leaf pack.
    Looking for any information on how to remove an upper ball joint with a press. I cant find anything regarding this!
    My truck is a 2012 TRD. Im replacing the upper and lower ball joints, looking for tutorials on how this is done.
    Thanks
  2. Mar 29, 2019 at 9:00 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    YOUTUBE THAT SHIT !
    Outdoorsy_Yota likes this.
  3. Mar 29, 2019 at 9:04 PM
    Taco_Rama12
    Martin
    Portland, OR
    Ive been Youtubin the shit out of it. But cant find my style of upper ball joint, and how to press this dam thing out and install a new one.
  4. Mar 29, 2019 at 9:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Lbj is extremely difficult to DIY without a shop press
  5. Mar 29, 2019 at 9:06 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall Modified bed extender
    Wow!!!
  6. Mar 29, 2019 at 9:07 PM
    Taco_Rama12
    Martin
    Portland, OR
    I rented a press for the LBJ, i will be doing that in a day or so. But the upper i tried to press out and cant get that dam thing moving...... . Lost at this point. I ordered a control arm with a pressed ball joint. But wondering if anyone has done this.
  7. Mar 29, 2019 at 9:09 PM
    anthony250f
    Anthony
    San Diego, CA
    Good luck
    Hope you have a torch or a extreme air impact. For some reason these lbj’s are Very difficult to remove. Difficult to install as well
  8. Mar 29, 2019 at 9:10 PM
    anthony250f
    Anthony
    San Diego, CA
  9. Mar 29, 2019 at 9:13 PM
    Taco_Rama12
    Martin
    Portland, OR
    Nice, Ill save that one for later. But find me one that shows the upper!! cant find anything for showing that upper ball joint removal anywhere! pain in my Ball Joint!!!!
    kfs90 likes this.
  10. Mar 29, 2019 at 9:23 PM
    anthony250f
    Anthony
    San Diego, CA
    I have never seen anyone remove the upper. Most people just buy a new arm lol
  11. Mar 29, 2019 at 10:30 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2006 Pre-Runner TRD Sport
    2005 to 2012 Front End Mod 3" 810lb IronMan TOYO50C coils 4" MaxTrac Spingles 35.6"x 12.8" Amp Off-road A/T PPro Dodinson front struts and rear shocks Deaver AAL Custom 4" Aluminum single piece driveshaft 2012 Interior 2009 J-VIN Japanese made 1GR-FE Cali Off-road Anarchy PVD wheels 20"x10" etc.... Lol!
    What would be the point in doing so anyway, you wouldn't gain anything?
  12. Mar 29, 2019 at 10:32 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is that picture of the truck on the ground or on a lift?
  13. Mar 29, 2019 at 10:34 PM
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Just buy my used uca. Only 90k easy freeway miles
  14. Mar 29, 2019 at 10:34 PM
    jboudreaux1965
    Joseph
    Hub City
    Lol, if that's a pic on the ground he got bigger probs
  15. Mar 29, 2019 at 10:42 PM
    Yota_Ivan
    Yota_Ivan Geaux Tigers!
    Ivan
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    I pressed mine out and it took me a lot of effort. Next time, I'd buy the whole UCA assembly.
  16. Mar 29, 2019 at 10:47 PM
    anthony250f
    Anthony
    San Diego, CA
    You get a Brand new ball joint, so what do you mean?
    Also if you upgrade you gain a uniball and more caster
  17. Mar 29, 2019 at 10:57 PM
    jboudreaux1965
    Joseph
    Hub City
    On an OEM UCA? I didn't know you could replace with uniball to OEM UCA!
  18. Mar 29, 2019 at 11:02 PM
    anthony250f
    Anthony
    San Diego, CA
    You can’t. I’m saying if you replace the entire uca to a uniball style
  19. Mar 29, 2019 at 11:12 PM
    jboudreaux1965
    Joseph
    Hub City
    OK, on the same page :)
    This is what I honestly see here... The more I look at it...
    Someone wanted to lift this truck cheaply. Bought, guessing... Toytec coil overs.
    Removed the top hat bolts, removed the lower strut bolt, pry bared the OEM the assembly.
    Went to put the new 'coil overs' in. Doh!!! These are longer, once the UCA drifts that low the spindle hits the coil!
    Instead of doing it right, they took a grinder to the spindle to shave it down and crow bar the assembly in place without removing the LCA to seat the new assembly.
    Then OP bought it.
  20. Mar 29, 2019 at 11:15 PM
    anthony250f
    Anthony
    San Diego, CA
    You have definitely lost me
    Those are 100% oem upper control arms. They aren’t grinded down, they aren’t broken or ruined visibly. I highly doubt anyone took a grinder to the spindle either? Also those look like bilstein shocks up front. Nothing wrong with that lift, aftermarket control arms would be better, but op’s suspension looks done right to me.
