upper ball joint spindle stuck to control arm
Discussion in '1st Gen. Tacomas (1995-2004)' started by Conner_carlson, Jul 9, 2021.
  1. Jul 9, 2021 at 9:58 AM
    Conner_carlson
    Conner_carlson [OP] Member
    Conner
    2000 Tacoma v6 trd
    bilstein 5100s
    I’m replacing my front struts on my 2000 Tacoma and I can’t get the upper control arm to pop off of the upper ball joint spindle. I’ve used lots of penetrating oil and hammering the knuckle and upwards on the UCAs and it won’t release on my passenger side. Any ideas or tips?
  2. Jul 9, 2021 at 10:08 AM
    yotadude520
    yotadude520 Well-Known Member
    Will
    The Dirty T
    1986 Toyota Land Cruiser
    OME Lift - FJ62 Axles - 33x10.50 BFGs
  3. Jul 9, 2021 at 10:14 AM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Are you using a mallet/deadblow or a metal hammer? A mini sledge or even a heavy carpenter's hammer should do the trick if your hitting on the flat surface.
  4. Jul 9, 2021 at 10:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Did you remove that ring/clip?
  5. Jul 9, 2021 at 10:19 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    The ball joint studs are taper fit into the upper control arms. You can use the ball joint puller linked... I generally have had to use some big hammer encouragement to help them separate. With a little pressure on the puller, I usually hit the control arm itself with a few solid blows, and it separates.
    The bigger question I have is... why are you removing the ball joint to replace a coilover?
    Digiratus likes this.
  6. Jul 9, 2021 at 12:19 PM
    Conner_carlson
    Conner
    2000 Tacoma v6 trd
    bilstein 5100s
    I’m putting in bilsteins set to 3 inches and can’t fit them in with the drive attached
  7. Jul 9, 2021 at 12:20 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Buy some replacement CV's now.
    Caddmannq and Black DOG Lila like this.
  8. Jul 9, 2021 at 12:48 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    1st, 5100s don't go to 3". Those are 2.5" max.
    2nd, why are you trying to remove the UBJ if you're just doing your shocks?
    3rd, your CVs aren't going to like you with that much lift and no other modification (diff drop, high angle CVs)
  9. Jul 9, 2021 at 1:01 PM
    Conner_carlson
    Conner
    2000 Tacoma v6 trd
    bilstein 5100s
    Yes I meant 2.5, the largest lock ring. 2, I couldn’t get the lower control arms low enough to seat the bottom bolt for the shock, and I am installing a diff drop next. The upper ball joint is hitting the coil when there is no weight on it (i finished the driver side) I’m not happy with toytec lifts at the moment as they told me many times I would not have to get and extended parts for long travel builds.
  10. Jul 9, 2021 at 1:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're far from having long travel.
    You just need to push down your assembly and the lower bolt then lines up with your LCA
    I did the bottle jack method with it on the upper control arm. Some loosen their cam bolts.
  11. Jul 9, 2021 at 1:13 PM
    Conner_carlson
    Conner
    2000 Tacoma v6 trd
    bilstein 5100s
    I tried to do it initially without undoing the swaybar and upper control arms, but what ended up being the issue was I could get it low enough but then the UBA would hit so I couldn’t get the bolt through. Hence I had to undo the UBA, put the bottom bolt on the strut in, then jack the lower control arm to reconnect the UBA with the upper control arm. I have left the jack there to mimic how it will sit with weight, so the upper ball joint doesn’t hit. Once again, praying the shocks settle, I’m worried that if the shocks ever get stretched, it will hit and hurt my shocks. and I will have to put the shocks on a lower lift setting.
  12. Jul 9, 2021 at 1:57 PM
    jbrandt
    Justin
    I think you're going at it backwards, if I'm understanding you correctly. I've done this several times on multiple tacomas and you shouldn't have to remove the UBJ to replace the shock.
    Use the bottle jack or loosen the cam bolts (and the UCA bolts) as @Kwikvette said, enough to slide the coilover in. Then install the 3 bolts on the top of the coilover/shock bucket. Then mess around with the bottle jack until you can get the lower bolt aligned and pushing in. Tighten, done.
    The shocks for Tacomas are designed to be the limiting factor for down travel. Once installed, that's the limit of the travel. If you go long travel, which you are no where close to doing with this setup, then people start putting limit straps on.
  13. Jul 9, 2021 at 2:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Removing the 4 bolts holding the lower ball joint to the spindle is way easier than separating the upper control arm from the spindle.
    se7enine likes this.
  14. Jul 10, 2021 at 10:35 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I bought one of those to remove the outer tie rod. The fork part of the tool broke off during the pull, but at least the tie rod came undone.
  15. Apr 3, 2022 at 9:44 PM
    kylefowler
    kylefowler Tallus_the_Taco
    Kyle
    Jackson, Wyoming
    Brute Force Fab Hybrid Front Bumper, Smittybilt XRC 9.5k, Pelfrybelt Swing Arm Bumper (With North Shore style bike rack installed), Icon King 2.5" lift, Pioneer AVH44000- NEX, BF Goodrich 285/85/R16, K&N Cold air intake Camper: ARE DCU 30"-36" shell (interior build coming soon.
    Somewhat unrelated to this topic. But I am using a bearing press form Napa, ECC on Fri p to get my uniball out of my icon UCA.
    I have not found a video on how to remove the uniball using the bearing press, rather then the Icon specific "on vehicle replacement kit".
    Does anyone have suggestions?
    Also the uniball could be seized in the control arm? If someone has recommendations for that please seizure help is appreciated.
  16. Apr 4, 2022 at 9:08 AM
    Madjik_Man
    Colorado Front Range
    @TMFF is incredibly knowledgeable with these things. Maybe he can help.
  17. Apr 5, 2022 at 4:27 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    im confused here
