Quick Links:Is there anyway to convert both electric windows to auto?
Door rod middle clips?
Bolt Size to Use with Puller, to Remove Crankshaft Timing Sprocket on 3.4L V6 5VZ-FE? Harmonic balancer - do i have enough room for an impact?
Brightest led bulbs on the market for turn signals/brake lights/ reverse lights
What is this Gasket?
Upper Ball Joint w / Lift & squeaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by BAZZMAZZA, May 28, 2012.
