Upper Ball Joints
Discussion in 'Arizona' started by cmack, Dec 23, 2011.
  1. Dec 23, 2011 at 5:07 PM
    cmack
    cmack [OP] Impeach Chris4x4!
    Went to change my pass side one out today and got it out of the UCA and then the spindles said :brianr: and no go. SO, monday I'm going to probably just remove the spindle and the UCA and see if I can find a shop with a press that can press the old one out of the spindle and the new on into the UCA and the spindle. I tried a BFH and the 3 arm clamps from HF. That worked for the UCA...
    Anyone know of such a shop that can do this? Located in N. Phoenix, bordering N. Scottsdale. Or does anyone here have a press we could use for it? I know it's holiday time, but I need to get this shit done by early next week.
    It's rigged up like this and sitting until I can get it sorted out.
  2. Dec 23, 2011 at 5:32 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAR
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    dam that sucks soak it down with pb blaster . or try a little heat on the spindle not smoking hot just get it warm
  3. Dec 23, 2011 at 9:06 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    there's a desert rat on cave creek and bell road.
  4. Dec 24, 2011 at 12:49 AM
    cmack
    Brian (BFA) and I spoke on the phone and he's going to help me tomorrow night or Sunday night. :) He's done a few sets and has a couple tricks. I'm going to remove the UCA and spindle and we're going to press the old out of the spindle and the new in the spindle and UCA at his place and then I'll just bolt up and be good to go.
    Sometimes having the taco out of commission isn't so bad. Gives me a chance to appreciate the other rigs....
  5. Dec 24, 2011 at 12:55 AM
    cmack
    Pretty he's got a press or is renting one for it. Will be easier not doing in the wheel well I guess :laugh:
  6. Dec 24, 2011 at 1:51 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    warning. brian is a noob at this.
  7. Dec 24, 2011 at 1:58 AM
    cmack
    He said on the phone he did yours and his. This is the first time I personally have done the upper ball joints before.
  8. Dec 24, 2011 at 2:33 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Gardnerville, Nevada
    No Truck
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    hey connor if the UCA's are still on the truck take a 10-15 pound sledge & give the UCA's a couple good whacks right in the area where the ball joint comes thru. the UCA (DO NOT HIT THE BALL JOINT ) just the UCA.
    After you do that find a hardened impact socket that will fit over the stud & is equivlent to slightly smaller than the ball joint. Now take the sledge @ hit the socket hard & squarely 4 or 5 times & it should just about fall out on its own....;):)
  9. Dec 24, 2011 at 4:39 PM
    cmack
    The ball joint is still on the spindle, but not the UCA. I managed to get it out of the UCA, just the spindle said :brianr:
    Tomorrow I'm going to remove the spindle and UCA from the truck and go to Brians (BFA) hopefully and we can get it out and the new one in. My 35mm or 36mm deep socket seemed to fit it well. Might take some swings at it before I go to Brians and get some anger out :D
  10. Dec 24, 2011 at 4:44 PM
    EL TACOROJO
    BURRY
    south mills NORCAR
    did you happen to remove the retaining clip from the top of the balljoint ?
  11. Dec 24, 2011 at 4:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    No Truck
    OH SHIT CONNOR, before you beat on anything check for big C-clips !!!
  12. Dec 24, 2011 at 4:47 PM
    cmack
    The snap ring? Is it sitting between the ball joint and the spindle? Cause like I said the UCA and the ball joint are disconnected. I know the new one came with one but I was searching for the old one and didn't have much luck....
  13. Dec 24, 2011 at 4:47 PM
    EL TACOROJO
    BURRY
    south mills NORCAR
    hmmm :D them fuckers got me before
  14. Dec 24, 2011 at 4:49 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    No Truck
    I just PM'd him about that too
  15. Dec 24, 2011 at 4:49 PM
    EL TACOROJO
    BURRY
    south mills NORCAR
    it doesnt stick out much . run a flat head screw driver around the top of the balljoint
  16. Dec 24, 2011 at 4:52 PM
    cmack
    Mine was on there good if it's what I'm thinking of..............I have a grinded down flathead screwdriver as a chisel. So BFH and hit it around to try and get it off? That small lip between the spindle and the ball joint?
  17. Dec 24, 2011 at 5:39 PM
    EL TACOROJO
    BURRY
    south mills NORCAR
    yup should be a groove with the clip in it . get 2 flatheads and pry it up and work it around and it should pop off
  18. Dec 24, 2011 at 6:07 PM
    cmack
    Will tackle it tomorrow. :anonymous:
  19. Dec 25, 2011 at 5:49 PM
    cmack
    Finished. I hate c clips. Gave me the most trouble. Oh well it's done and over with.
  20. Dec 25, 2011 at 5:52 PM
    EL TACOROJO
    BURRY
    south mills NORCAR
    Right on. Glad it was just that and nothing worse
