Upper Ball Joints
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Nov 19, 2012.
  1. Nov 19, 2012 at 7:18 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    I'm having a hard time finding what i'm looking for. Maybe i'm just not typing the correct words in the search box. anyways..my upper ball joint boot is blown open on the driver's side. is there a repair boot for this? also, from looking at these UCAs they appear to be like my integra... can these ball joints be pressed in and out or does the whole UCA need replaced?
  2. Nov 19, 2012 at 7:21 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
  3. Nov 19, 2012 at 7:22 AM
    danteisme
    South Western PA
    ah ok, so it is a "serviceable" part if i go aftermarket?
  4. Nov 19, 2012 at 7:22 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
  5. Nov 19, 2012 at 7:22 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    I have some stock factory UCA's with less than 5K on them. PM me if interested
  6. Nov 19, 2012 at 7:24 AM
    danteisme
    South Western PA
    i'd like to just replace the boot if possible first, i'm not sure if the ball joints are worn or not yet. i'd assume they are getting close at 95K miles. i'll do some more digging and let you know if i need the UCAs.
  7. Nov 19, 2012 at 2:20 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Replace the ball joints with messed up boots dirt and water gets in there and screws them up.
  8. Nov 19, 2012 at 9:37 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Get you some Moog BJ's, rent you a BJ press from the parts store, and you are golden. There are replacement boots, but with the cost of new BJ's, the boots don't make sense.
  9. Nov 21, 2012 at 10:17 AM
    danteisme
    South Western PA
    From my Haynes manual it says "it may be possible to have the balljoint pressed out of the arm by an automotive machine shop or repair shop that specializes in suspension work. A replacement part may be available as an aftermarket (non-oem) part, but this could not be confirmed at the time of this manual's writing)"
    i see aftermarket ones, i'll just assume they can be pressed out of the control arms.
  10. Nov 21, 2012 at 10:21 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yes the ball joint can be pressed out. They gave you the Moog replacement part numbers above. It may or may not be something you would be able to replace yourself, but they are replaceable. The Moog bj's actually come with a zirk fitting so you can grease them too
  11. Nov 21, 2012 at 10:22 AM
    danteisme
    South Western PA
    i love moog replacement parts, the oem parts shoould come with the zerks
