Upper bell housing bolt
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PineappleMan, Jul 24, 2023.
  1. Jul 24, 2023 at 5:43 PM
    PineappleMan
    PineappleMan [OP] Member
    2015 Tacoma SR5 4x4
    Hey guys,
    I have a 2018 Off-road MT, I just replaced the clutch and I’m struggling with getting the transmission back mated to the engine. I was able to get 5 of the bell housing bolts threaded through, 4 of them are the 14mm bolts and one of them is the passenger side 17mm bolt. However, the 3 17mm bolts near the starter will not thread through. I’ve dropped the transmission and readjusted a million different ways to no luck. Wouldn’t the fact that 5 of the bolts are in align the other 3 regardless?
  2. Jul 24, 2023 at 5:51 PM
    Bishop84
    Bishop84 Well-Known Member
    If its not flush with the dowel pins lined up the 17mm will never go in.
    You need to look carefully through the sides and see if the trans is flush with the engine. Just because the bottom is clocked right doesnt mean flush.
    HondaGM, shakerhood, HP11 and 5 others like this.
  3. Jul 24, 2023 at 6:35 PM
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    ^^This^^. Probably the input shaft splines are binding. Gotta wiggle the hell out of it. Not good to try and pull it in with the bolts.
    HondaGM, Chew and PineappleMan[OP] like this.
  4. Jul 24, 2023 at 7:49 PM
    PineappleMan
    2015 Tacoma SR5 4x4
    so you’re saying the top could be pulled further away while the bottom is touching?
    HondaGM and Bishop84[QUOTED] like this.
  5. Jul 25, 2023 at 4:32 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Bishop84 is spot on correct. Do not attempt to close the gap with the bolts.
  6. Jul 25, 2023 at 4:55 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There are two different bolt lengths. I'm betting that might be the issue?
    HondaGM likes this.
  7. Jul 25, 2023 at 5:09 AM
    PineappleMan
    2015 Tacoma SR5 4x4
    The two different bolt lengths are only between the 17mm bolts and the 14mm bolts :/
    HondaGM likes this.
  8. Jul 25, 2023 at 5:12 AM
    AM6217
    Its probably tilted slightly . So the bottom bolts and the lower side bolts will go in. But not the top. It has to be parallel with the block and slid in. So the pins and the splines line up. Videos will show guys rocking back and forth or up and down slightly until they mesh together. When this is achieved you should be able to run them in with your fingers.
  9. Jul 25, 2023 at 5:13 AM
    AM6217
    Bishop has knowledge
  10. Jul 25, 2023 at 5:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No. There are two different lengths of the 14mm bolts.
    HondaGM likes this.
  11. Jul 25, 2023 at 5:19 AM
    PineappleMan
    2015 Tacoma SR5 4x4
    Is it slight? I have them stood next to eachother and can’t see the difference
  12. Jul 25, 2023 at 5:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Check all of them. It is enough length difference for the shorter ones to not thread into the deeper holes.
  13. Jul 25, 2023 at 5:42 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I’ve noticed that putting a very small amount of grease on the dowel pins helps when sliding things together. Also you’ll want to make sure that the plane of the bell housing matches the angle of the engine. You might need to have someone adjusting the engine angle while you stab the transmission. Good luck!
    shakerhood and 33yrsoftoys like this.
  14. Jul 25, 2023 at 5:48 AM
    33yrsoftoys
    joel
    mid Michigan
    Try to jack up the rear of the trans/transfer case 1/16". Then wiggle it while pushing forward. Gotta be careful you don't damage the pilot bearing. It'll go.:thumbsup:
  15. Jul 25, 2023 at 9:18 AM
    PineappleMan
    2015 Tacoma SR5 4x4
    C4701324-FF76-465B-87E6-D6FD382E33FA.jpg 7BD69078-550D-4AC9-B6D1-781E38D25088.jpg Here are two photos. One are the bolts I am working with, all the 14mm are same length and all the 17mm are same length.
    the other picture shows the holes I’m struggling with
    I took the transmission back off and tried threading bolts into each hole. The only two holes which would not thread are the two that go into the starter. I have no idea what to do
  16. Jul 25, 2023 at 9:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Those sure look to be M10 and M12 bolts.
    I was confused by 14mm and 17mm bolts.
    Delta09 likes this.
  17. Jul 25, 2023 at 9:47 AM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Just a wild guess here as I’m not fully sure what I’m looking at.
    How about a spud wrench? If there is room for you to use a spud wrench with one hand and see if you can adjust to help start the other side.
  18. Jul 25, 2023 at 9:49 AM
    PineappleMan
    2015 Tacoma SR5 4x4
    After removing the entire transmission and just trying to thread bolts into the holes on the engine block, I think I had everything lined up. Because the two bolts going into the starter holes, wont thread even without the transmission there.
  19. Jul 25, 2023 at 10:27 AM
    TXBoss
    TXBoss Well-Known Member
    DFW
    2009 & 2015 TRD Sport
    Probably already mentioned, but run a thread tap through those (once you ensure you have correct thread and pitch) and get rid of any burrs you may have. Go easy.
  20. Jul 25, 2023 at 10:43 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    He done forgot more than we will ever know...
