Upper control arm bolt is spinning.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bryanh69, Feb 11, 2023.
  1. Feb 11, 2023 at 7:28 AM
    bryanh69
    bryanh69 [OP] Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    I am putting on a set of 3rd gen takeoffs and most everything is going great.
    My problem is the bolt in the UCA is just spinning when I am trying to tighten the castle nut up. I have it far enough on that it lines up the pin perfectly. Is that far enough?
    There isn't a space to put another wrench anywhere to help here.
    Ideas?
  2. Feb 11, 2023 at 7:32 AM
    Bishop84
    Bishop84 Well-Known Member
    Pry down on the arm with a pry bar to put pressure on the ball joint to stop it from spinning.
    I usually put some lubricant on the threads if its doing this as well to help reduce friction.
    cloudbnd likes this.
  3. Feb 11, 2023 at 7:34 AM
    bryanh69
    ok....I will try that
  4. Feb 11, 2023 at 7:43 AM
    bryanh69
    @Bishop84
    Thanks.
    I don't know that its 84 fl/lbs. But its for damn sure gudentite. And the pin lines up.
    Bishop84 likes this.
