Upper control arm help please!
Discussion in 'Suspension' started by adamv22, Jun 4, 2011.
  1. Jun 4, 2011 at 10:00 PM
    adamv22
    adamv22 [OP] Well-Known Member
    adam
    29 Palms, California
    06 tacoma Sport
    6" Rough Country lift, Toyota roof rack, Tepui RTT, Hidden 12000lb winch Pioneer 6.1 DVD stereo, Cobra III CB radio,
    Im putting a small lift on my 06 tacoma, and ive been fighting for a day and a half on how to disconnect the upper control arm from the ball joint. ANY advice would be greatly appreciated!!
  2. Jun 5, 2011 at 5:56 AM
    jmdaniel
    jmdaniel Has A Well Known Member
    Jeff
    Leander, TX
    2018 Tundra SR5 CrewMax
    Two words: Pickle fork.
  3. Jun 5, 2011 at 8:59 AM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    wack it wit hammer
  4. Jun 5, 2011 at 9:02 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Unless you are replacing the UCA, there's no need.
    Why are you trying to disconnect it :notsure:
  5. Jun 5, 2011 at 9:06 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Wait - why are you trying to disconnect the UCA from the ball joint? That bad boy is pressed in there.
    I think *MAYBE* what you mean is that you want to disconnect the ball joint from the spindle. In that case, you can use a pickle fork - but they're mostly designed to separate the ball joint when it's going to be replaced. Since you plant to reuse it, you may want to use a ball joint puller instead.
    Some guys have success with a BFH (Big effin' Hammer) - if you do that, leave the castle nut over the end of the ball joint so you're not whacking on the threads.
  6. Jun 5, 2011 at 9:08 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also - the alternative method for replacing the struts is removing the tie-rod end, instead of disconnecting the ball joint.
    Again, you may want to use a puller.
  7. Jun 5, 2011 at 9:13 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    If all you ar doing is isntalling a lift, then just remove the two bolts on the bottom of the lower ball joint. (17 or 19mm if i remember correclty). Once you remove thoes you can move the entire spindle out of the way and pull out the shock/spring assembly.
    No need for disconnecting any ball joints, no pickle fork, no bullshit. Easy peasy.
  8. Jun 5, 2011 at 9:31 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    i wish i could offer help here. i'm about to under take this shit job next week some time. installing a lift and going with the light racing uca's. snap some pics during your removal man.
  9. Jun 5, 2011 at 9:49 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    If you're just going to replace the UCAs then all you have to do is take the pin and nut off from the bottom of the ball joint and smack it off the UCA with a hammer or a pickle fork.
    But loosen the main bolt of the UCA first and take off the bracket holding the lines onto the UCA.
  10. Jun 5, 2011 at 11:09 AM
    adamv22
    adam
    06 tacoma Sport
    Thanks to everybody that had some input it all helped i got the pickle fork and that got the tie rod end disconnected.. i found another option, if i remove the sway bar, i almost have enough room to slide the bottom end of the shock into place after the top 3 bolts are lined up, but now i need about one more inch before itll be in place.. FML
  11. Jun 5, 2011 at 11:12 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    You can always disconnect the lower ball joint from the spindle with the 2 bolts. Then get a cranking strap to bring the upper control arm down when you get the shock in. Had to do this for my dads truck....
  12. Jun 5, 2011 at 11:14 AM
    adamv22
    adam
    06 tacoma Sport
    thats the two bolts outside of the larger bold on the bottom correct?
  13. Jun 5, 2011 at 11:19 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Need an inch...use your bottle jack. Works every time:
  14. Jun 5, 2011 at 4:32 PM
    adamv22
    adam
    06 tacoma Sport
    5 Hours and a smashed finger later, im done. thanks guys ill get some pics up sometime soon
  15. Jun 5, 2011 at 4:38 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Bad advice from every one. Next time use a ball joint seperator. Picklefork you have a possibility of damaging the boot, and whacking it with anything you'll surely damage somthing.
  16. Jun 5, 2011 at 4:48 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Everyone eh? You must not have read everyone's post then.
  17. Jun 5, 2011 at 4:51 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I have ADDHDHDHD
  18. Jun 5, 2011 at 4:53 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Perhaps you should unplug your keyboard then.
  19. Jun 5, 2011 at 4:56 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    That would require disassembly of the lap top and with my expirience in that kind of disassembly it will open up a rift it the time contimuim.
