Upper control arm help!!
Discussion in 'Suspension' started by xTACOMAx, Mar 11, 2014.
  1. Mar 11, 2014 at 8:32 AM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    I read somewhere if you have adjustable uppers that you could run 285's without wheel spacers, is that true? If so can you just run A/T's or M/T's and also if you can with the M/T's can you run the M/T's on the rear without wheel spacers? I think you can but I was just going to ask that to cause I'm not sure. Thanks!!
  2. Mar 11, 2014 at 8:35 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  3. Mar 11, 2014 at 8:43 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Not sure what a/t or m/t has to do with size... but if you want to run 285's on your stock wheels you will need spacers. You wouldn't need spacers if you got some wheels with 4.5 inches or less of backspacing.
  4. Mar 11, 2014 at 8:53 AM
    xTACOMAx
    07 prerunner TSS
    Ok thanks, both a/t and m/t are rated to be 11.5" wide but the m/t are wider than 11.5 nitto trail grappler are wider and toyo m/t are wider than 11.5 that's just a few.
  5. Mar 11, 2014 at 8:53 AM
    xTACOMAx
    07 prerunner TSS
    * few tires.
  6. Mar 11, 2014 at 9:03 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    I have no idea what you just said... 285 is the width of the tire though, 285 mm is roughly 11.25 inches.
  7. Mar 11, 2014 at 12:30 PM
    xTACOMAx
    07 prerunner TSS
    If you could or if you can measure from side wall to side wall and include the side wall tread the m/t tire would be wider than a a/t tire and a 285 ( I'm just guessing here) on average is 11.50" wide, some m/t tires are wider than that.
  8. Mar 11, 2014 at 12:50 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Doesn't matter if the tire is an A/T M/T H/T or whatever, 285 is 285, they may be a couple of mm's off, but I wouldn't say every m/t is wider than any other style of tire. The cooper A/Ts I'm running are just as wide as the M/T's they replaced.
  9. Mar 11, 2014 at 12:55 PM
    xTACOMAx
    07 prerunner TSS
    Ok but anyways back to my question I will still have to have wheel spacers no matter what?
  10. Mar 11, 2014 at 12:59 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    For stock wheels, yes, if you were to get aftermarket ones that have 4.5 inches of backspacing or less, then you would not need them.
  11. Mar 11, 2014 at 1:01 PM
    xTACOMAx
    07 prerunner TSS
    Ok thanks so if had adjustable uppers would they be any longer or shorter?
  12. Mar 11, 2014 at 1:03 PM
    xTACOMAx
    07 prerunner TSS
    Than the stock ones
  13. Mar 11, 2014 at 1:18 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    The SPC /Light Racing are basically the same dimensions as the stock upper control arms.
