Upper control arm question?
Discussion in 'Suspension' started by TRD2006, Oct 20, 2013.
  1. Oct 20, 2013 at 2:04 PM
    TRD2006
    TRD2006 [OP] Well-Known Member
    stock 2006 4x4 TRD Sport
    I installed the 5100's a while back and just curious of I need upper control arms after the install, the truck seems to wander all over the road going down the highway, and the steering wheel seems jump when you hit a bump I believe it's called bump steer, the truck was lifted 2.5" in the front by compressing the stock springs and was lifted in the rear with a 2" add a leaf. I'm just trying to see if the upper control arms are needing replaced?
  2. Oct 20, 2013 at 2:10 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    did you get an alignment?
  3. Oct 20, 2013 at 2:22 PM
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    It varies apparently from truck to truck but I have the same set-up with no issues for over 2 yrs now. No wandering & tread wear is fine.
  4. Oct 20, 2013 at 3:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any lift over 2", and you loose caster. New UCA's that have added caster will correct this issue, and allow for proper alignment.
  5. Oct 20, 2013 at 3:05 PM
    TRD2006
    Okay because my alignment was still done " the best it could be"
  6. Oct 20, 2013 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, they will allow for more camber, to try and eek out a little more caster. Most often, its barely in specs.
  7. Oct 20, 2013 at 3:24 PM
    TRD2006
    But that should fix both issues?
  8. Oct 20, 2013 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    New UCA's, like Light Racing, or Total Chaos, will fix everything. They add caster, allowing the Camber to be set closer, or better, than it is now, while adding Caster to stop the wandering.
  9. Oct 20, 2013 at 3:29 PM
    TRD2006
    Where would be the best priced place?
  10. Oct 20, 2013 at 3:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check with our vendors. Try Downsouth Motorsports.
  11. Oct 21, 2013 at 11:16 AM
    TRD2006
    Does anyone know if anyone is running a GROUP BUY or anything on the Light Racing UCA?
  12. Oct 31, 2013 at 12:08 PM
    spartanhockey6
    spartanhockey6 My truck rattles, A LOT.
    Trevor
    Talent, OR
    2010 White Trd Sport
    Money Pit
    I have the OME complete with the 885's and am looking into some new UCA's, just don't know which ones to buy, LR or total chaos? i haven't much information on what owners prefer.
  13. Oct 31, 2013 at 12:18 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have OME 886 and I like my LR UCAs. Got them front Metal Tech 4x4, also Fat Bobs Garage had a good price.
  14. Oct 31, 2013 at 12:27 PM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
  15. Oct 31, 2013 at 12:39 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    Yeah i'll probably go with LR's...just doing some more research on uni ball vs ball joints. I live in southern california but Oregon is home and the roads are rocked and salted pretty much from Nov- Mar.
  16. Oct 31, 2013 at 1:24 PM
    monstertaco12
    Louisiana
    Yup. Pretty good bang for the buck
  17. Oct 31, 2013 at 1:29 PM
    Colt562
    Colt562 Well-Known Member
    Brett
    SoCal
    13' TRD Sport 4x4
    Icon Stage 3 Lift Kit...Dakars
    check out headstrongoffroad.com
    best prices and will beat any price from another company. I highly recommend them.
    As far as UCA's, can't go wrong with Icon Tubular/Total Choas/Camburg/LR.
  18. Oct 31, 2013 at 1:35 PM
    AllMountainToy
    AllMountainToy Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    Light Racing! I am running them with my complete OME 3" and solved all my alignment issues and coil rubbing UCA issues.
  19. Oct 31, 2013 at 9:37 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
  20. Nov 1, 2013 at 6:07 AM
    monstertaco12
    Louisiana
