Upper control arm removal problem....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vpcustoms, Mar 16, 2020.
  1. Mar 16, 2020 at 6:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Pro tip!
    Place tape on the fender that you intend to bend, this limits the scratching. The passenger side is more difficult, it takes time.
    Some pro's cut the head of the bolt off and replace it from the bottom. I don't like this method. Failure means the bolt falls out.
    SR-71A likes this.
  2. Mar 16, 2020 at 6:08 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Yes. That’s what I did.
  3. Mar 16, 2020 at 6:14 PM
    ToyotaDriver
    Idaho
    True, but is there record of one ever failing? I’d be pretty surprised if the answer is yes.
    Muddinfun likes this.
  4. Mar 17, 2020 at 10:04 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    A shop that cant use common sense,or use the internet for answers ?
  5. Mar 17, 2020 at 1:10 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Yes. It has happened. Ask me how I know.... :anonymous:
    LAMCKMA007 likes this.
  6. Mar 17, 2020 at 3:13 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Every single one of you is out of your mind for criticizing the shop here. Yes, removing the bolt is not hard, I've done it myself. It requires a decent bit of grabbing the sheet metal with channel locks or other pliers and bending it out of the way. I don't care how non-essential that sheet metal is, if any shop took pliers to a painted sheet metal surface and tweaked it the way this job requires without having a detailed conversation with me first, I would be absolutely pissed. No competent shop is just going to start irreparably bending the fuck out of body metal. I bet many out there wouldn't even do it at all, even if the customer cleared them. This is a sign of a good shop, not a bad one.
  7. Mar 17, 2020 at 3:16 PM
    kfs90
    kfs90 Well-Known Member
    BR, LA
    2013 Prerunner V6
    #triggeredlol
  8. Mar 17, 2020 at 3:24 PM
    andrew61987
    Which is the right move. Best would be to give the choice with a disclaimer on the quicker method, but I would not expect any shop to default to that method.
  9. Mar 17, 2020 at 3:32 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay well, if we are being anal about things...
    The OP stated that the mechanic just says he cannot remove the bolt without it hitting the frame. Nowhere on there did he state that the tech said, "I can bend the body metal out of the way slightly just to get the bolt back and bend it back in when I'm done." No. This guy said it to him like he was stumped and couldn't see past the line where the sun meets the ocean. Similar to the insight that my dog has when he looks out of the window. Not a whole lot going on upstairs.
    Disclaimer is the right way to go about it if it is at a shop, it can be done one of two ways and the most undesirable and time consuming way would cost $$$$ more.
    whatstcp[QUOTED] likes this.
  10. Mar 17, 2020 at 4:12 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Critical rhinking is the name of the game. It's what separates real techs from oil changers. Actually it's what the lack of turns techs into oil changers.
    boogie3478 likes this.
  11. Mar 17, 2020 at 7:22 PM
    ToyotaDriver
    Idaho
    :popcorn:
  12. Mar 17, 2020 at 7:37 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    How do you know?
  13. Mar 17, 2020 at 7:46 PM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    This. For real.
    I’d understand a competent, non-professional, mechanically inclined getting stumped for a bit before figuring it out, but a professional working at a shop? No sir.
    It’s a PITA but very doable.
  14. Mar 30, 2020 at 3:37 PM
    RIDINRICKY
    RIDINRICKY Well-Known Member
    Rick
    So Cal
    07 prerunner access cab speedway blue
    17" wheel upgrade (stock), de-badged, Bird Dawg mirror lift kit (awesome!), 3rd Gen f coilovers, Flowmaster, more coming.....
    I'm not a suspension guy. That said, what would be the difference of these two positions of tightening the bolt? I ask so I can learn. Thank You.
  15. Mar 30, 2020 at 4:00 PM
    #35
    Muddinfun
    Muddinfun Well-Known Member
    The rubber in OEM type bushings is designed to stretch when the control arm moves up and down. The rubber should be relaxed at ride height so it can stretch in each direction as the control arm goes up and down. If the bolt is tightened at full droop, then the rubber is stretched at ride height. Then when the suspension compresses, it stretches the rubber farther than it’s designed to go.
    dk_crew and RIDINRICKY[QUOTED] like this.
  16. Mar 30, 2020 at 4:03 PM
    #36
    RIDINRICKY
    Rick
    So Cal
    AHHH! That is good info. Thanks Man!
    Muddinfun[QUOTED] likes this.
  17. Mar 30, 2020 at 5:39 PM
    #37
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Which results in what exactly?
  18. Mar 30, 2020 at 6:14 PM
    #38
    Muddinfun
    Destroyed bushings.
  19. Mar 31, 2020 at 3:15 PM
    #39
    SUMOTNK
    Eddie
    Had a shop do the uca install (stock to SPC)..they didnt loctite the nut/bolt. 20k+ miles later, Nut backed off, that long threaded bolt started to slip out...one arm of the UCA slipped out of angle and pressed against the engine.
    Somehow got lucky that all this happened when leaving a costco parking lot and not at speed. Immediately felt alignment was off and stopped. Got out of truck, and camber was out of whack and saw the A-arm. Towed it home, jacked it up,and replaced nut and bolt..loctite this time. Learned my lesson the hard way.
    Luckily, no damage because of this....but now my spc uca on that side is noisy as f*ck. Due to bushing or lack of grease. UCA is still straight.
    LAMCKMA007[QUOTED] likes this.
