Upper control arm replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Uvince, Nov 30, 2019.
  1. Dec 1, 2019 at 2:25 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    How do you go about bending the bolt? How so you straighten it once you want reinstall?
  2. Dec 1, 2019 at 2:30 PM
    DG92071
    DG92071 Well-Known Member
    BEND THE SHEET METAL OUT OF THE WAY. DO NOT BEND THE BOLT.
    Watch the video.
    whatstcp, gasgasman and scottalot like this.
  3. Dec 1, 2019 at 2:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Evaluate any rust / corrosion carefully.
    It's easy to break or strip a bad bolt, then you'll have to cut it out.
    If the area appears dicey corrosion wise, it's not a bad idea to have a couple of new bolts on hand. Just in case. Either that or another transportation method until you can source new ones.
    BTW, with that potential problem in mind, park it where it can be out of the way for a day or two. Just in case.
  4. Dec 1, 2019 at 5:00 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    Mo corrosion. I'm in Arizona. :) it's warm here too. I was planning to bend the metal. Thanks for all the responses.
    DG92071 likes this.
  5. Dec 1, 2019 at 8:32 PM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Correct. I bend the shit out of the sheet metal and the bolt was a long way from being able to slip past the sheet metal.
    Much to many TacomaWorlder's disagreement, I cut the bolt, and put it back in the other way.
    DG92071[QUOTED] likes this.
  6. Dec 1, 2019 at 8:37 PM
    Uvince
    Uvince [OP] Member
    Uvince
    2005 Prerunner
    What year?
  7. Dec 1, 2019 at 8:41 PM
    badger
    badger Well-Known Member
    07 SR5
    My bolts are in backwards, and always will be.
    JeffBoyardee likes this.
  8. Dec 1, 2019 at 8:44 PM
    JeffBoyardee
    Jeff
    Seminole, FL
    Thank you. Totally agree with this. There are MANY other bolts that could potentially fall out and cause our trucks to reduce themselves into kit form, according to that line of thinking. I put a touch of loctite on them, and I check them pretty regularly.
    gasgasman likes this.
  9. Dec 1, 2019 at 8:55 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  10. Dec 1, 2019 at 8:59 PM
    badger
    07 SR5
    I'm curious.....does anyone have a link to even one case of these backward bolts coming out that was properly torqued to begin with? I'm going out on a limb here, and predicting the answer is "no".
    DG92071 likes this.
  11. Dec 1, 2019 at 9:36 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Check out my post (#17) on 1st page of this thread.
  12. Dec 3, 2019 at 6:37 AM
    gasgasman
    gasgasman Well-Known Member
    LOL. No one is worried about the lower control arm bolts falling out.
  13. Dec 3, 2019 at 6:52 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If your not worried about it, why check them pretty regularly. I wouldn’t do it but the chances of them coming out probably aren’t that high of torqued and loctited.
  14. Dec 3, 2019 at 11:16 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Because it's a pivot bolt, and it's aftermarket. If I'm down there greasing them, why not go ahead and check it. I check my lugnuts pretty regularly too. But I wouldn't say I'm "worried" about them flying off.
    gotoman1969[QUOTED] likes this.
  15. Dec 3, 2019 at 11:29 AM
    #35
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    FYI- If you put the bolt in backwards the truck will throw a code and end up in limp mode
    nd4spdbh likes this.
  16. Dec 3, 2019 at 11:55 AM
    #36
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    You’ll have no problem doing the replacements being it’s an AZ truck. I had to cut out my LCA’s a few weeks ago. The cam bushings were frozen and no heating, witchcraft or impact tools would make them budge. I had to replace w/ MOOG due to time constraints. What are you using as replacement parts?
  17. Dec 3, 2019 at 12:38 PM
    #37
    JeffBoyardee
    Jeff
    Seminole, FL
    I don't have faith in your logic. :D
  18. Dec 3, 2019 at 1:58 PM
    #38
    81Trekker
    La Jolla SD
    It’s not my logic it’s a TW law!
    JeffBoyardee[QUOTED] likes this.
