Upper control arm swap... How much play?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Velellavelella, Dec 22, 2022.
  1. Dec 22, 2022 at 8:27 PM
    Velellavelella
    Velellavelella [OP] New Member
    Kris
    4WD / 2001 / 3.4L V6 / XtraCab
    Hi everyone,
    I swapped in a new set of upper control arms (MOOG, which I'm coming to understand was a mistake, but we can discuss that another time). When I tighten down the UCA through-bolt, I lose all play in the UCA other then what's provided by the torsion of the bushings—i.e., the bolt tension loads the sleeve inside the bushings against the sleeve on the shock mount. The whole assembly binds there, leaving just the bushing flex to absorb any UCA motion. I still get a fair bit of motion, maybe 6" vertically when rocking them by hand.
    I've watched a handful of videos and this isn't addressed. Is this what I want? Intuitively, I'd think that the system should be rotating freely (on the bolt?).
    Thanks for your expertise.
    - Kris
  2. Dec 22, 2022 at 9:48 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Welcome to TW. Sorry I don’t get your issue clearly.
    Do you have washers over the bushings? Did you grease the bushings or possibly over tighten the bolt?
  3. Dec 22, 2022 at 9:56 PM
    Velellavelella
    Kris
    Thanks. Washers yes, on the outside of the UCA, where the bolt head and nut contact it. Oriented with the convex side facing outwards relative to the UCA, towards the head and nut respectively. No room for washers between the UCAs and shock mount sleeve. I definitely didn’t over tighten. A half turn on the nut past hand tight causes it to freeze up.
  4. Dec 23, 2022 at 12:35 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    they're bound bushings. once its tightened down, all the movement is in the bushings. the main bolt should be torqued with the weight of the truck on the arm. same as the lower control arm bushings.
    Bivouac, lambo and mattyosh like this.
  5. Dec 23, 2022 at 1:21 AM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    ^^ yepp, any suspension component that has rubber bushings should be torqued at ride height.
  6. Dec 24, 2022 at 11:25 AM
    Velellavelella
    Kris
    Thank you all! I would not have guessed that.
  7. Dec 24, 2022 at 12:09 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Yeah, they are twisty bushings, same as the lowers. It eliminates squeaks.
