Upper control arm to high
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01tacoma2430, Oct 25, 2020.
  1. Oct 25, 2020 at 9:57 PM
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    Wut in tarnation
    :eek:
    CygnusX191 and oakcity like this.
  2. Oct 25, 2020 at 9:59 PM
    eon_blue
    Azusa, CA
    His profile says he hasn't logged in since before the first reply in this thread, so he likely have even seen any of these responses yet.
  3. Oct 25, 2020 at 10:30 PM
    Running Board Man
    Running Board Man Well-Known Member
    If you look closely I want to say it looks like there's a drop-down bracket look at the nut and bolt we're he control arm would be look where the bump stop would be
  4. Oct 26, 2020 at 1:33 AM
    oakcity
    oakcity Well-Known Member
    Jesse
    Raleigh, North Carolina
    2009 Grey Tacoma AC 4x4
    Money Pit
    Oh yeah I think you may be right, a lot of people talking about the spring being collapsed but wouldn’t it be smashed like that with 6 inches wedged in there? Or is the drop bracket supposed to correct that someway?
  5. Oct 26, 2020 at 1:49 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    That's what she said.
    :rofl:
    MattCowsmasher and CygnusX191 like this.
  6. Oct 26, 2020 at 2:18 AM
    oakcity
    Jesse
    Money Pit
    I’m serious lol I don’t know a lot about 6 inch lifts don’t they alter the line with the drop bracket? And spindles?
  7. Oct 26, 2020 at 2:22 AM
    Key-Rei
    Key
    Florida
    Yeah a drop bracket drops the bottom attachment point for the lower control arms, then a spacer "extends" the factory shock to fill in the "gap" so that the stock uper and lower control arms maintain a "factory" geometry just separated 6 more inches now, the last piece of the puzzle is then extending the spindle to also fill in the "gap" as you can see here it's done with a "grenade" spacer typically they're done with lift spindles but this isn't an option as far as I'm aware with the Tacoma for 4WDs.
    oakcity[QUOTED] likes this.
  8. Oct 26, 2020 at 2:25 AM
    oakcity
    Jesse
    Money Pit
    Yeah all those spacers must be harsh...
  9. Oct 26, 2020 at 6:21 AM
    Running Board Man
    Look at he diff mount in the pic of the kit and on the truck it does have a drop down bracket
  10. Oct 26, 2020 at 6:33 AM
    oakcity
    Jesse
    Money Pit
    Yeah I believe it is one, he must not have done the install himself or her self I guess we will never know this will end up like the 8k lbs winch thread :rofl:
  11. Oct 26, 2020 at 6:36 AM
    Running Board Man
    Almost like op made a 1/4 inch homemade bumper
    Slashaar likes this.
  12. Oct 26, 2020 at 6:38 AM
    jandrews
    '09 FourDubDee TRD OR
    This is the problem.
    "I want to lift my truck but the budget is $300".
    Then you ain't liftin' your truck.
    It's not worth it to fuck with anything less than new coilovers, new shocks, add-a-leaf at minimum (new leaf packs better by far).
    And to really do it correctly, you're gonna need to extend your brake lines and upgrade your control arms to allow for recovery of lost downtravel in the suspension so it doesn't ride like a pile of ass over potholes.
  13. Oct 26, 2020 at 6:49 AM
    jmferg
    jmferg Well-Known Member
    agreed. There is a difference between lifting you vehicle for bigger tires and putting a true suspension lift on your vehicle that works off-road.
    you could put spacers on and get an alignment for $300.
    If you went full budget, a proper 2-3" lift would be $1,500 still
    bilstein 5100s
    coils
    top hats
    extended front brake lines
    Upper control arms (recommended but not necessary)
    diff drop (again, recommended but not necessary)
    leaf springs
    longer rear shocks
    extended bump stops to protect shocks
    extended rear brake line
    e-brake ext.
    alignment
  14. Oct 26, 2020 at 7:05 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Looks like you installed the bump stop spacer in the ball joint. There's no bump stop it looks like on your truck right now.
    Juisebocks likes this.
  15. Oct 26, 2020 at 7:25 AM
    #35
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You guys are silly, a spacer doesn’t cost 300$. I think I spent 80 on mine.
    And I know you don’t want to admit it, but a spacer will work for 90% of the people on this site. They just aren’t as likely to get a big gram following.
  16. Oct 26, 2020 at 7:40 AM
    #36
    jandrews
    "Will work" and "done right" tend to be far apart. I recommend high standards.
  17. Oct 26, 2020 at 7:43 AM
    #37
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Maybe OP is too embarrassed to come back. I would be
    :anonymous:
    Slashaar, Key-Rei, Astr0Aar0n and 3 others like this.
  18. Oct 26, 2020 at 7:44 AM
    #38
    JKO1998
    Utah
    Only reason to have kings on vehicles that aren’t gonna see worse than a dirt forest road is for approval on social media
  19. Oct 26, 2020 at 7:52 AM
    #39
    Slick Taco
    Kings for the win at the mall too :p
    CygnusX191 likes this.
  20. Oct 26, 2020 at 7:58 AM
    #40
    Running Board Man
    I can drink to that
    CygnusX191 and Slick Taco like this.
