Upper Control Arm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aportis72, Feb 28, 2012.
  1. Feb 28, 2012 at 4:34 PM
    aportis72
    aportis72 [OP] Well-Known Member
    Austin
    Supercharger
    im looking at buying the Icon Billet Upper Control Arm. I was wondering if these are the best UCA out there. Are there better ones if so what are they.
    Also has anyone installed these before
  2. Feb 28, 2012 at 4:41 PM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    The icons are great, but I just couldn't justify the cost, I went with the desert racing ucas from DSM. I'm 100% happy with them and I got them for roughly half the price of the icons.
  3. Feb 28, 2012 at 4:42 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Waiting on my winning lottery numbers to get mine
  4. Feb 28, 2012 at 4:44 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    I went with total chaos . Forgot what I payed because it was with my winning scratch ticket. I'm happy with them .
  5. Feb 28, 2012 at 4:47 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    I have Total Chaos UCA's, as well.
  6. Feb 29, 2012 at 10:13 AM
    aportis72
    Austin
    Supercharger
    So is there any real advantage to the icon billet ones.
    Also someone did I write up on an install and he had to hack and cut the crap out of his sheet metal to get them in?
  7. Feb 29, 2012 at 10:15 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Baller status.
    You have to move the sheetmetal out of the way to get the UCA mounting bolt out on each side. The suspension is assembled at the factory before the body is dropped onto the frame.
  8. Feb 29, 2012 at 10:20 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    How are they holding up with the salt in New England?
  9. Feb 29, 2012 at 10:23 AM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    the icon billet UCA's have a sealed uniball don't they? makes them last longer right?
  10. Feb 29, 2012 at 10:25 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Or cut the bolt and replace it backwards
  11. Feb 29, 2012 at 10:25 AM
    johnnym
    john
    NH
    I just put them on 2 weeks ago . But I'm sure I'll be replacing the uniball . I put the tri flow lube on which is like a silicone "almost" to keep most of the salt out but we will see what happens .
  12. Feb 29, 2012 at 10:27 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    :rolleyes: that's an interesting option...
  13. Feb 29, 2012 at 10:28 AM
    OZ-T
    Peter North
    British Columbia
    Wut ? It works
  14. Feb 29, 2012 at 10:30 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    not saying it won't...actually saying that's a good idea...dk what a new bolt would cost though...if it's not too much it'll save some pain of getting that bolt out and bending the sheet metal
  15. Feb 29, 2012 at 10:31 AM
    OZ-T
    Peter North
    British Columbia
    IIRC they are about $15 each at the dealership , that being said I bent the sheet metal myself
  16. Feb 29, 2012 at 10:31 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    The truth^
  17. Feb 29, 2012 at 11:00 AM
    mjp2
    NJ
    Buddy of mine did exactly that. His truck is pristine and he didn't want to touch the sheetmetal.
    Worked like a champ and the cost of the bolts was worth it to him.
  18. Feb 29, 2012 at 11:24 AM
    Large
    Large Red
    I did total chaos, clock had 2k on her. You could cut the sheet metal, bend it back, then use a bfh to beat it where it belongs. When you get done you can't tell unless you get real close.
  19. Feb 29, 2012 at 5:06 PM
    aportis72
    Austin
    Supercharger
    Wow design flaw if you actually have to cut and bend the metal. Thats just stupid. I will be cutting them and buying new bolts. Anybody have the part number on them? And is the right and left the same part number.
    Thats just dumb that you have t do that.
  20. Feb 29, 2012 at 5:12 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    as far as bolt..yes they are the same type of bolt
