Upper control arm?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bigblue2011, Mar 23, 2018.
  1. Mar 23, 2018 at 7:20 AM
    Bigblue2011
    Bigblue2011 [OP] Member
    Austin
    2011 blue tacoma prerunner
    6inch lift 32 inch light bar
    I’m going to be putting 20x12 rims with 33s on my tacoma truck has a 6 inch lift. Should I leave the stock control arms or replace them?
  2. Mar 23, 2018 at 7:32 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    What's your reasoning for getting new ones? With the DB brackets, I though all your stock suspension geometry remains the same.
    Aftermarket UCAs usually help those doing suspension lifts to get their caster back in spec. I'm not entirely sure when it comes to the DB lifts.
  3. Mar 23, 2018 at 8:46 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You don't need too replace the uca's with a DB lift
  4. Mar 23, 2018 at 9:42 AM
    Bigblue2011
    Austin
    I have the max trac 6.5 I believe so I should be okay with the stock arms you think?
