Upper Control Arms and Tire Size
Discussion in 'Wheels & Tires' started by sodak, Dec 21, 2008.
  1. Dec 21, 2008 at 3:00 PM
    sodak
    sodak [OP] Member
    2008 Tacoma
    I'm thinking about replacing the upper control arms with aftermarket ones to allow a larger tire size, then upgrading the tire size with no lift.
    Does anyone know the max size/width you can gain from the aftermarket UCA's (total chaos, I think)?
  2. Dec 21, 2008 at 3:08 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    The UCAs don't give you additional tire clearance. The lift does. The UCAs allow you more travel and help you correct alignment issues after lifting.
    Also, I think if you put the Total Chaos UCAs on a stock suspension, you'll have too much caster and won't be able to get it aligned properly... I think I read Chris4x4 or Toku say that once... :)
  3. Dec 21, 2008 at 4:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep. The TC arms add 2+* more caster. If you have too much caster, the front tire will rub the rear part of the wheel well.
  4. Dec 21, 2008 at 4:21 PM
    sodak
    sodak [OP] Member
    2008 Tacoma
    Thanks both for the advice. Longhorn, your lift looks great! How far down does the diff drop go? I hate to lift my truck, then lose all that ground clearance dropping it.
    I was off roading this summer, and put some nice "character" in my skid plates. I need more clearance, but don't want to get too high.
  5. Dec 21, 2008 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its a 1" drop, but as it only drops the front of the diff, total drop is only 1/2"
    Ooppsss.....You asked Longhorn. Sorry.
  6. Dec 21, 2008 at 4:29 PM
    sodak
    sodak [OP] Member
    2008 Tacoma
    No problem at all, thanks for the info! That's not bad.
  7. Dec 21, 2008 at 4:35 PM
    LonghornTaco
    Minnesota
    Yeah, but he got the answer from the master! The man from whom I learned everything I know.... :)
  8. Dec 21, 2008 at 5:24 PM
    sodak
    sodak [OP] Member
    2008 Tacoma
    How about all the little things, like extending brake lines, lifting the proportioning valve, etc. Are those necessary with the 3 inch lift? Also, do the driveline angles stay pretty much within spec? Sorry for all the questions, but this is the lift that I'm looking at. Thanks!
  9. Dec 21, 2008 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I didnt have to extend the brake lines on my rear lift (2"), nor the BPV. Drive angle are on the fringe of being in spec. Some people develope drive line vibes, while others havent. There is a carrier bearing drop kit (Just 2 spacers for the bolts), and axel shims availible if drive line vibes are present. I have no vibes and I havent installed any axels shims, or dropped the carrier bearing.
  10. Dec 21, 2008 at 6:43 PM
    LonghornTaco
    Minnesota
    How much was the new drive shaft? And how is it better? Just that it's a single piece or is it stronger too?
  11. Dec 21, 2008 at 7:00 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    TW DS is still only 4x4, correct? Still no Prerunner friendly model?
  12. Dec 21, 2008 at 8:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They should be able to make you one.
    X2
