Upper control arms close to tire after lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by jeg0005, May 23, 2019.
  1. May 24, 2019 at 3:54 AM
    #41
    jeg0005
    jeg0005 [OP] Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
    I was rubbing before the lift with 265 75 r16s, so maybe I should get some anyway. I'm doing the rear end today. Once I have it completely on it's own weight I'll torque everything down again and take it down the street to get aligned and see where that puts me.
  2. May 24, 2019 at 3:54 AM
    #42
    jeg0005
    Jon
    BHM, AL
    That's light reflecting off of the glossy surface haha
  3. May 24, 2019 at 3:58 AM
    #43
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ah okay, I see now. If you rubbed before, yeah you may want spacers.
    Those 3rd/2nd gen wheels look great, but I dont advise 1st genners to use them because of this exact issue. Its why I ditched mine and went back to a more friendly offset.
  4. May 24, 2019 at 4:58 AM
    #44
    trdproven
    trdproven Well-Known Member
    mines farther but it still rubs on the side threads of the duratracs. hit even hits the spindle and the control arm areas after i hit bumps cus i see the rub shiny areas.
  5. May 24, 2019 at 11:50 AM
    #45
    Wheeler's Off-Road Inc
    Wheeler's Off-Road Inc Well-Known Member
    Grants Pass, OR
    If the tires do not contact at normal operating heights, take er' in for a proper alignment. The shop will see that and adjust accordingly while getting you in the green on the alignment. Those SPC arms have quite a few different adjustments to be considered unlike other arms/brands. OEM wheels don't leave a whole lot of back spacing room for larger off-road tires. Hub centric wheel spacers may be needed.
    jeg0005[QUOTED][OP] likes this.
  6. May 24, 2019 at 12:18 PM
    #46
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    ECCPP 6x5.5 Wheel Spacers Hubcentric 6 lug 2X 1.25" 6x5.5 to 6x5.5 106mm Fits for Toyota Tacoma Tundra Sequoia FJ Cruiser 4 Runner with Thread Pinch 12x1.5 https://www.amazon.com/dp/B01IV2524M/ref=cm_sw_r_cp_apa_i_-ke6CbCZ90EES
    Put them on a wish list and they'll drop the price 5% about a week later. Also by them one at a time so the coupon applies to both sets. Got mine for less than $70 shipped.
  7. Oct 15, 2019 at 9:48 PM
    #47
    tacothyme
    tacothyme Well-Known Member
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
    Just picked up some of these to compare to some spidertraxx. Have you had any issue running with these spacers?
  8. Oct 15, 2019 at 11:11 PM
    #48
    grrillA
    grrillA Well-Known Member
    Long Beach, CA
    '99 3.4L 4x4
    If you are running lets say , as close as you could 1/4 inch or so. You air down, wouldnt the sidewall then potentially contact ?
    Ritchie likes this.
  9. Oct 16, 2019 at 2:28 PM
    #49
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Bingo! Mine are near as close as OP. Aired down, they do rub - not so much the wheel/tire won't roll. Data: 285/75R16 BFG A/T, stock 2002 Tacoma aluminum rims, OE control arms, 2-1/2" sway-a-way front struts
  10. Oct 17, 2019 at 1:55 AM
    #50
    jeg0005
    Jon
    BHM, AL
    I think I’m just going to go with some Bora 1” spacers
    CS_AR likes this.
  11. Oct 17, 2019 at 4:21 AM
    #51
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Check out this thread below. Check to see if you have longer lug bolts on the rear compared to the front.
    For my 1999 Prerunner, it took 1" Bora on the front and 1.25" Spidertrax on the rear to get it right. It made for .25" wider stance in the rear. Once I replaced the ProComp wheels that required spacers with some Methods, I no longer needed the spacers. Also, I was having problems with the truck wandering on the road at high speed. I removed the spacers and that took care of that problem. It did handle nicely on curvy roads. But on the interstate, it got old fast. So I think I struck the right balance between handling and straight out driving with the right wheels.
    I might try the spacers again just for kicks later in the winter. My only disappointment in this deal was in talking to Bora about the lug bolt length difference. I was told that "we've sold a pallet load of Tacoma spacers" and never had any issues with lug stud length differences. It turns out that other members have reported this difference. I felt like I was being "blown off" about the lug stud length difference. Also, buying a fairly common product with a 3-week order fulfillment turnaround time is just not with the times. So I learned yet another lesson.
    This is a known issue for some Tacomas. When I talked to @Wheeler's Off-Road Inc about the difference while purchasing a different product, they were interested and listened.
    You can see the pictures of the differences in this thread.
    https://www.tacomaworld.com/threads/bora-spacer-problems-solved.611840/#post-20744047
  12. Oct 17, 2019 at 10:20 AM
    #52
    TheGoat
    Justin
    Greenville, SC
    No issues, still working fine.
  13. Oct 17, 2019 at 5:33 PM
    #53
    jeg0005
    Jon
    BHM, AL
    The only time I really experience any serious rubbing is when I turn the wheel to the right while reversing. There is some light rubbing at full lock on either side. But it's not bad. I have see marks on the UCAs though where the tires have rubbed them.
