Upper control arms recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 802 taco, Apr 14, 2021.
  1. Apr 16, 2021 at 11:54 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    If you replace your coilovers then your stock UCA might rub against the newer coil at or near full droop. This is due to the larger overall diameter of some aftermarket coils.
  2. Apr 17, 2021 at 4:52 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I have about 3k miles and one mild weekend of off road on them. No issues. Quiet, feel like stock as far as ride and steering. Greasable with zerks.
  3. Nov 1, 2021 at 12:04 PM
    Taco600mpg
    Taco600mpg Well-Known Member
    Cam
    14 regular cab 5 speed manual
    2.25 inch lift, Firestone airbags, 235/85/16 tires, k&n 63 series cold air intake, LCE header and exhaust, nfab prerunner light bar, trd skid plate 3rd gen oem knock off, ecometer, kc lights, trd grill emblem, trifold bed cover, cb radio and antenna, pedal commander, volant ram air scoop, daystar airbag cradles, trd off road 3rd gen rims, hood hinge light mounts, bilstein 5100 shocks and 5100 struts set at 1.75 lift, strut spacers to gain . 5 more inches of lift, Jba standard high caster upper control arms
    How good are dirt kings
    And there quality of ball and bushings
    811901
  4. Nov 1, 2021 at 12:15 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    How are you determining that your ball joints are worn out? I have 10k on my SPCs and they seem fine, but I haven’t tried to remove them and inspect them for wear. I dunno why road salt would be a issue provided you keep them greased.
  5. Nov 1, 2021 at 12:35 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    How Toyota's own used in the 2022 Pro...yes they have upgraded the UCA with some nice TRD billet by the looks of it.
  6. Nov 1, 2021 at 1:30 PM
    Taco600mpg
    Cam
  7. Nov 1, 2021 at 4:06 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
  8. Nov 1, 2021 at 4:13 PM
    Taco600mpg
    Cam
  9. Nov 1, 2021 at 4:20 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I did the 2" Bilstein 5100's with stock coils (as per Bilstein). That's all I did. Think it becomes a problem once you go to a wider tire, like 285 width.
    Maybe those people can answer it better than I can, as I only went with a 265/75/16 tire.
  10. Nov 1, 2021 at 4:25 PM
    Tacomod
    Tacomod Well-Known Member
    Aftermarket UCAs allow your suspension to droop more without making contact. It depends on how much travel your suspension has, if it's a lot you're gonna want aftermarket UCAs even with only 2" of lift. If it's a budget setup you're probably fine with stock UCAs.
  11. Nov 1, 2021 at 4:38 PM
    lalonguecarabine762
    lalonguecarabine762 Well-Known Member
    Brodey
    2022 F150 Tremor
    Previous 2016 TRD Offroad
    I have Camburg ball joint UCA's and have not had any trouble. I have probably done less (read nothing) to maintain them since they were installed and still have zero issues.
    If you are doing a lift and they have all the parts off I would just spend the little extra money and get the UCAs. Then there is no question of clearance and you don't have to go back and try and fix it later if you have problems.
    Tacomod likes this.
