Upper Control Arms, Yes or no?
Discussion in 'Suspension' started by Lifeofbrian, Feb 15, 2018.
  1. Dec 1, 2020 at 11:21 AM
    #41
    Kingair84
    Kingair84 Well-Known Member
    Wisconsin
    2016 Double Cab TRD Off Road 6 speed MT
    Rad Industries skid plate, trd pro grill, rigid DOT Fogs
    I have the same question.
  2. Dec 1, 2020 at 11:23 AM
    #42
    eon_blue
    Azusa, CA
    Probably not. Every case is a little different though and you won't know for sure until after the lift and you get it aligned. But most likely a 2" lift won't require aftermarket UCAs.
  3. Dec 1, 2020 at 11:25 AM
    #43
    Kingair84
    Wisconsin
    Awesome! Thanks.
  4. Dec 2, 2020 at 10:53 AM
    #44
    PinktacoDM84
    PinktacoDM84 Well-Known Member
    Dan
    BC
    2015 trd OR/AC
    St Maxx on Trd pro wheels, mbrp exhaust, k&n cai, jba's, 887's over 5100's, medium dakars and 5125's.
    The general consensus is always 3+ inches or very near to that, and you will need uca’s. However I don’t think it hurts to get them at anywhere from 2” up. The oem ones are junk, and what’s $600 spent on a good truck?
    when I went from 2”-2.5” I got uca’s and my alignment is now perfect because of that.
  5. Dec 2, 2020 at 5:42 PM
    #45
    CoyoteCalling
    CoyoteCalling Well-Known Member
    3rd Gen DCLB Silver
    SPCs are unquestionably worth it. You're already in there working, get it all swapped out and beefed up the right way the first time. The new UCAs allowed me to fit 285/70/17 with minor trimming and no rubbing issues hence.
  6. Dec 8, 2020 at 8:43 PM
    #46
    Jukeboxx13
    Jukeboxx13 Well-Known Member
    California
    2017 TRD OR DCSB 4x4
    whats bump steer?
  7. Dec 8, 2020 at 9:53 PM
    #47
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    is the JBA STD UPC just as capable as the SPC?
  8. Jan 9, 2022 at 6:07 PM
    #48
    T-Dozzer
    T-Dozzer Well-Known Member
    Getting ready to put ARB nitro sport coil overs on. I thinks its around a 2" lift all said and done. 265 tires, but considering 285s
    Ya'll think I need UCAs?
  9. Jan 9, 2022 at 6:18 PM
    #49
    Kingair84
    Wisconsin
    I’ve been running 2” now for almost a year. In my case there was just enough adjustment left to get my truck in alignment without UCAs and it’s driven great ever since. No unusual tire wear either running general grabber AT2 tires.
  10. Jan 9, 2022 at 6:43 PM
    #50
    T-Dozzer
    Thanks. I've had a 2" lift on using front spacers (for tire clearance) for years now w/o alingment issues. I was just curious if I "needed" them going to a strut/coil lift. Might try it without UCAs first.
