Upper Control Arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seniorredwood, Dec 23, 2016.
  1. Dec 23, 2016 at 5:59 PM
    seniorredwood
    seniorredwood [OP] Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    I feel like I can already see the outside edge wearing down. Maybe I'm just looking too hard though.
  2. Dec 23, 2016 at 6:02 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I would bump the 5100s down a notch or two. It will ride and wear much better. Unless you already crammed 33's on there..
  3. Dec 23, 2016 at 6:03 PM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    Dont you have a depth gauge? Theyre cheap for piece of mind.
  4. Dec 23, 2016 at 6:07 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    He can ask for 2.5 caster all he wants, but it's not possible with stock control arms.
    Blackout14 likes this.
  5. Dec 23, 2016 at 6:09 PM
    dpi
    dpi Well-Known Member
    Dan
    Tulsa, OK
    AFE Stage 2 SI CAI Banks 3" Mandrel bend Cat Back dpi Rock Sliders
    They didn't touch your caster or camber. They only adjusted the toe. Take it back and tell them to do a true alignment and to set the caster as high as they can get it.
  6. Dec 23, 2016 at 6:14 PM
    seniorredwood
    Pennsylvania
    Fucking assholes. I knew 500 for installing my lift tires and rims was too good to be true.
  7. Dec 23, 2016 at 6:19 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Yep, the closer to 3 degrees the better.
    He can get a lot closer than 0.8 that's for sure.
  8. Dec 23, 2016 at 8:03 PM
    Justinlhc
    Right, but asking for something that's not possible isn't going to do any good.
    Like I told him in his other post about this, he got a "toe and go" alignment from a lazy tech.
  9. Dec 23, 2016 at 8:17 PM
    badger
    badger Well-Known Member
    07 SR5
    With stock control arms, the alignment you got was most likely the best they could do. They could reduce your camber a bit, and get a tiny bit more caster, but no where near what you need. They can't just "dial in" what you want when the adjustment is at it's limit.
    The numbers that you show, if they are correct, should not be visible to you, and should not be causing any increased wear. Something doesn't add up! If you can see your tires leaning in, then those numbers are not right.
    If you drop back down to 2" of lift, you can probably get your caster to the minimum level, BUT on a lifted truck, A better value is around 3 degrees.
    Bottom line, you have two choices:
    1. Drop to 2 " of lift, set your camber low, and try to get your caster to the minimum setting. You will get good tire wear, but your steering will be a bit twitchy, and your truck will tend to wander. I drove many miles like this, and you kind of get used to it.
    2. Buy a set of adjustable UCAs like the Light Racing set-up. Then they can set your caster to 3 degrees and keep all the other numbers good. Keep the camber near the low end though! You can also move your lift back to 2.5.
  10. Dec 23, 2016 at 8:18 PM
    badger
    07 SR5
    Justin is right...
  11. Dec 23, 2016 at 11:29 PM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    Yeah. According to that list doesn't even really look like they touched anything. lol. Surprised they had the balls to even print it out and give it to you. My guy was able to get me 1.9 caster on stock UCA with a 3.25" lift. I will eventually get some TC but not in any rush as the truck rides fine. Take your vehicle to a better shop.
  12. Dec 24, 2016 at 5:24 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    to me appears to be a (to much negative) camber issue not so much caster.
  13. Dec 24, 2016 at 7:39 AM
    Justinlhc
    I'm not sure I understand what you're saying.
    His slightly positive camber is actually halfway decent. It's his low caster that's a huge problem.
    I could get him a better alignment in my garage in about 10min with basic hand tools and my eyeballs.
  14. Dec 24, 2016 at 7:46 AM
    badger
    07 SR5
    X2....his camber is actually good for these trucks. The higher end of spec wears tires. The caster is actually a safety issue. If you are not "driving" the truck every second, it will wander off the road. I'm surprised they let you leave the shop like that. Caster is what keeps your truck steering ahead safely.
  15. Dec 24, 2016 at 12:41 PM
    #35
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    SPC arms and be done with it.
    I did 5100s at 1.75in and caster could only be about 1.5* which was a little low
    SPC arms, im at 3.4* caster per side, -0.4* camber, and .1* toe in per side and its PERFECT. tire wear is even and it tracks dead straight.
    Seriously dont bother with the stock arms especially at max lift height with the 5100's... one your stock arm likely hits coil at full drop, 2. upper ball joint is probably limiting droop, and 3. your alignment will ALWAYS SUCK. Spend the 400 bucks or so and get spc arms and be done with it and enjoy driving your truck again.
  16. Dec 25, 2016 at 10:48 AM
    #36
    lawrenccar1
    i though OP stated his wheels were leaning in at the top ? That is not caster.. to me sounds like strange camber
  17. Dec 25, 2016 at 11:24 AM
    #37
    seniorredwood
    Pennsylvania
    I've actually noticed this since I got the lift. It is a lot easier for me to end up over the line now
  18. Dec 25, 2016 at 11:41 AM
    #38
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    This is the closest to being right answer! It looks like all they did was measure and not make any adjustments at all. Shit was probably seized and they didn't want to screw with it. Not sure how people come to so many conclusions without knowing what tire size you run, either? Looking at the numbers, you must drive with the wheel turned a little to go straight(meaning the wheel is not centered)? They didn't do any adjustments at all or the caster numbers would have changed. Caster is basically front to back adjustment in regards to position of the wheel in the opening. It is impossible to adjust camber or caster without both changing a little. The only thing changed was camber and that was from the lift changing the angle of the wheel slightly, which is why the caster stayed the same, because they never turned the cam adjusters. When lifting, "in spec." in not necessarily what you want, but many shops will go there. Yours for the most part is within spec, but shitty for a lift
  19. Dec 25, 2016 at 11:57 AM
    #39
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    The total toe in the front after the alignment is 0.10" toe in. Within the specs.
  20. Dec 25, 2016 at 12:01 PM
    #40
    gottaToy
    JJ
    1985 Moped
    I read it wrong. The SAI(straight ahead) numbers are way off. Either way, they just put the shit on and made no adjustments. The alignment sucked before they did the work looking at the "before" measurements.
