Upper control arms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JJPotts, Feb 22, 2022.
  1. Mar 2, 2022 at 3:57 PM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Yes both our 2016 & 2019 Tacomas have 12 off set rims…both of us , run 32’s BFGs…plus both spares can fit..
  2. Mar 3, 2022 at 7:44 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    So 12 offset? How wide are your rims?
    My wheels are 9" wide with a -6 offset (4.75" BS) and I had no issues.
    With my wheels spacers (1.25") I'm now sitting at 3.5" BS and I have rubbing while reversing and turning or hitting bump while turning.
    But normal driving on the road it's fine.
  3. Mar 3, 2022 at 8:37 AM
    Lava-road
    2019 trd-off road
    9 inch ..275/70r/17. BFGs. … I am wondering will the off sets and how width of rims effects the rubbing?
    Done a CMC and moving my tires forward 1/2 inch help eliminate most of the tire rubs…a little tire rub while reversing on turns…just a little bit..
    Some Tacoma owners with 33’s do not get any rubbing? Is it the rim widths?.. and off sets?
    Aloha
  4. Mar 3, 2022 at 1:29 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    About to upsize to 285/75/16s and looking for the optimum offset and back spacing to avoid rubbing on cab and/or UCA. It appears after reading numerous posts a 16x7.5 or 16x8 wheel with a zero to a negative 5 offset and around a 4.5 to 4.75" back spacing would be the ideal setup. Not planning on running wheel spacers.
  5. Mar 3, 2022 at 1:31 PM
    Lava-road
    2019 trd-off road
    Good to know…Thank you…
    Aloha
  6. Mar 5, 2022 at 12:42 AM
    toku58
    Mall Crawler!
  7. Mar 5, 2022 at 5:07 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I've had both SPC's and JBA's. JBA's on the 2011 4Runner I just traded on my 3rd gen and SPC's on my last double cab second gen. Both at around 2.5" of front lift. If I had to do it again (and more than likely I will) I would go with JBA's again. I had those in my 4Runner for probably 40k miles and no issues. The things I really liked about them versus the SPC's is the bushings have grease fittings and the ball joint is a bolt-in style. If you ever have to replace the joint you just take it out and bolt a new one in. On the SPC the ball joint slides and pivots for the camber/caster change. No way would you be able to just pop that sucker out and get it remotely close without an alignment. And this is coming from a guy with an alignment machine at work. It's just a pain. And you could source the JBA joints locally. SPC not likely.
  8. Mar 5, 2022 at 9:01 AM
    Lava-road
    2019 trd-off road
    Great info…! SPC vs JBL….both grease able…
    My son’s I got him the JBL’s 2016 Tacoma TRD, on my 2019 Tacoma TRD. I got the SPC’s …
    If I do it again …UCA …something to consider if replacing the ball joints..?
    Did anyone replace there ball joints on the SPC’s upper control arms..? Any problems? Cost? Difficulty?
    Aloha
  9. Mar 5, 2022 at 10:26 AM
    Lava-road
    2019 trd-off road
    A bit pricy for SPC replacement ball joints ..costing from $130.00 to $180.00 for a pair…is what I found so far…
    Good to know you can order those complete ball joints..
    Aloha
  10. Mar 5, 2022 at 1:30 PM
    Lava-road
    2019 trd-off road
    In June 2021 ..Bilstein came out with there version for lifted Toyotas UCA …. Under $700.00 ..
    With Bilstein reputation….Now you can get a complete Bilstein shocks & UCAs…for the front…
    Aloha
  11. Mar 5, 2022 at 1:54 PM
    FloridaFree
    FloridaFree Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
  12. Mar 5, 2022 at 2:18 PM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    The below quotes are from the JBA Upper Boot Problem thread over in the 1st Gen section. JBA sorted out the issue with their boots, but the below info is what I found through researching the large list of UCAs for the Tacoma. My preference is JBA for the ease of sourcing and changing ball joints.
  13. Mar 5, 2022 at 3:32 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    Another question. When you ordered did you get the new or old style SPC? is it half tube or all forged
  14. Mar 5, 2022 at 3:39 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Icon CMC
    CaptainTikihut likes this.
  15. Mar 6, 2022 at 5:33 AM
    #35
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Newer style all forged, newer version of joints too.
  16. Mar 6, 2022 at 5:33 AM
    #36
    Tacoma091919
    Tim
    2019 OR DCLB
    Yes, they are all the same.
  17. Mar 6, 2022 at 7:53 AM
    #37
    FloridaFree
    TRD OffRoad 4x4 mgm
    Thanks for the info. I will jump on them some time later this week
  18. Mar 6, 2022 at 9:08 AM
    #38
    Tacoma091919
    Tim
    2019 OR DCLB
    Just check them when received before return window. I’ve heard some people got the older style joints but that was over a year ago so should be good. I bought the last set on hand when I bought mine last December, but the restocked.
  19. Mar 6, 2022 at 1:10 PM
    #39
    Lava-road
    2019 trd-off road
    Bilstein UCA will fit 2005-to 2021 Tacoma, Same like JBA upper controls will fit 2005-2021, and am sure most of the other brands will have the same fit…
    Aloha
  20. Mar 6, 2023 at 1:08 PM
    #40
    sjm.thomson
    sjm.thomson Member
    Scott
    2019 TRD OR Cement
    3" lift / Levelled / KO2 AT
    Just wondering if anyone has purchased recently?
