Upper Control Arms
Discussion in 'Suspension' started by Night hunter, Apr 20, 2022.
  1. Apr 20, 2022 at 1:03 PM
    Night hunter
    Night hunter [OP] Well-Known Member
    Rick
    2017 Black Tacoma TRD
    Kenda Klever AT2. Stock size
    If you got new Stock 265-65-17 tires can you put narrower upper control arms on your truck in case you want to go to a larger tire size later. I’m going to put better shocks and coils later because of brush guard weight and winch but I was just wondering if I could put Upper Control arms on and use them with my stock tires with the option of adding a little bit bigger tire later for clearance. I don’t plan on lifting it unless it would be a inch.
  2. Apr 20, 2022 at 1:39 PM
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
  3. Apr 20, 2022 at 2:12 PM
    AndrewMT34
    AndrewMT34 Well-Known Member
    WY/UT
    2019 Calvary Blue LB Offroad
    ADS/FOX/DEAVER
    Yep, shouldn't be a problem.
