Upper control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rob.94, Oct 23, 2024.
  1. Oct 23, 2024 at 1:40 PM
    Rob.94
    Rob.94 [OP] Member
    Rob
    I have a Tacoma with a 3 inch lift Can I get away with stock Uca’s?
    If not looking for recommendations on control arms.
  2. Oct 23, 2024 at 2:22 PM
    snook 32
    snook 32 Well-Known Member
    Herb
    Davie Florida
    08 pre runner
    check out JBA, not sure about stock uca's
  3. Oct 23, 2024 at 2:45 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    You could run them the issue will be getting good alignment numbers. I’ve run JBAs for 8yrs with zero issues in getting great alignment numbers and reliability of the components.
    Steves104x4 likes this.
  4. Oct 23, 2024 at 2:50 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's already running and driving with 3" lift? If the steering feel is acceptable to you, then carry on. UCAs are typically needed to bring caster closer to service manual limits, which affects steering self-centering behavior.
    Dirt King, Bilstein, Freedom Off-road, JBA all make acceptable ball joint UCAs.
  5. Oct 23, 2024 at 4:38 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I ran a 2.25" lift for a couple of years with stock UCAs. They will work but your alignment is not ideal and the tires will track easier on the highway. When I put JBAs on and got my alignment dialed in, it made a world of difference to the driveability.
  6. Oct 23, 2024 at 7:20 PM
    Rob.94
    Rob.94 [OP] Member
    Rob
    Thank you for the feed back. Pulls to the right, so I took it to a shop today for an alignment and they basically told me that I needed to get new uca’s and tie rods for it to be affective. It would be nice to stay with the stock ones, however I don’t know if that would cause damage to the rest of the front end/tires
  7. Oct 24, 2024 at 2:47 PM
    TacoTuesday1
    FL
    no printout never happened
    pull is typically from uneven measurements.
    You would have potentially good or bad measurements the same on both sides. Because they are the same.
    too much lift and stock UCAs gave me positive camber on both sides. Which is bad. And was even. It did not pull. It had positive camber tire wear, lack of grip, and ugly look.
  8. Oct 24, 2024 at 2:52 PM
    Clearwater Bill
    Billy
    Largo Florida
    4wd? nothing in your post or profile on that. Always helpful for folks to know.
    Lower the truck and the UCAs should be fine
    2 - 2.5 is the suggested max lift so the CVs are protected and scrub radius stays reasonable
