Upper/Lower/TieRod/Control Arm Kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jay24533, Jun 18, 2025.
  1. Jun 18, 2025 at 7:36 PM
    Jay24533
    Jay24533 [OP] Member
    Jesse
    2000 Tacoma TRD 4x4
    Is there a good complete Kit for front suspension, tie rod, upper and lower ball joints,etc...
  2. Jun 18, 2025 at 7:44 PM
    02hilux
    Planet: EARTH
    Yea, Toyota
  3. Jun 19, 2025 at 8:48 AM
    rish57
    rish57 Well-Known Member
    2000 Tacoma 3.4L SR5 4x4
    The general consensus is LBJ should be genuine Toyota for sure, outside of getting real high-end crazy stuff if you do agressive offroad stuff...I'd also personally suggest if you happen to do sway bar end links to stay away from brands like Moog...they are absolute garbage, and you'll find the factory ones are pretty pricey for a simple part, so either just replace the bushings or find a good aftermarket parts, I've seen some really good alternatives out there. As far as kits, just gonna have to do some research and put one together for yourself.
    mt50u1 likes this.
  4. Jun 19, 2025 at 9:33 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    The attached is for a 2003.
    There is no full kit. Toyota doesn't make coilovers any more, you'll want these, best price you'll find and they are assembled.
    Go OEM on critical parts for reasons mentioned above. Energy suspension for rack/sway bar bushings.
