Upper oil pan subbassembly replacement 2014 Taco 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johncus, May 28, 2020.
  1. May 28, 2020 at 3:03 PM
    johncus
    johncus [OP] Member
    john
    2014 Toyta Tacoma SR5 4x4 4.0 engine
    I bought this truck from an auction and realized the Upper oil pan subassembly is cracked and leaking engine oil.
    Apparently it got cracked while off-road, maybe from a jump and landing heavy on front wheels
    and front transaxle pushed against the case and cracked the aluminum.
    I looked into it at the dealers and the pan is available but I am not sure if I have to take
    the engine off the truck to replace this or can it be replaced in the truck?
    I'm sure the truck was ran after the crack and lots of oil got lost, but there is 3 quarts of oil left in there in the lower portion of the basin.
    Did anyone R&R this upper oil pan ?
    Any tips?
    I can up-load a picture tomorrow or this evening for reference.
  2. May 28, 2020 at 5:08 PM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Think you have to drop the front clamshell to access the upper oil pan.
    12TRDTacoma likes this.
  3. May 28, 2020 at 5:47 PM
    johncus
    johncus [OP] Member
    john
    I’m sorry, being new to the Tacoma trucks and new to terminology, I will have to ask stupid questions, what is “Front Clamshell”?
    Thanks
  4. May 28, 2020 at 6:49 PM
    johncus
    johncus [OP] Member
    john
    Here is the picture from the crack...
    If you notice the transaxles are right beneath
  5. May 28, 2020 at 6:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have a similar crack in mine.
    You basically have to remove the front differential assembly in order to gain access to it.
    I still have to do it, but have been running it that way for years with a patch up job. Been running tons of boost through it for over 5 years now making something north of 350HP. Everything has been fine. Eventually I'll have to fix it right, but for now, it'll do. :)
  6. May 28, 2020 at 7:14 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    It looks like it's near the steel oil pan. Is that right?
  7. May 28, 2020 at 7:34 PM
    Armkb
    09 TRD Sport DCLB
    Front clamshell is the differential. May want to try some JB Weld first. See if that holds. Never know.
  8. May 28, 2020 at 7:36 PM
    dtaco10
    Dave
    Second, JB Weld. Clean it up the best you can.
  9. May 28, 2020 at 7:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's exactly how my repair was done..
    Steelstik putty.
    It has to be putty style epoxy because the mix together stuff won't set due to gravity and the oil pan has to be drained if it is actively leaking from there. The affected area should also be cleaned using carb cleaner or similar to really get it nice and clean.
  10. May 28, 2020 at 7:44 PM
    johncus
    johncus [OP] Member
    john
    Yes its close to the steel pan, it appears that the previous owner might have a hard landing on the front wheels and engine kept traveling downwards flexing the motor-mounts and trans-axels traveling up and crushing into each-other cracking the upper aluminum pan as in picture.
    If i was to guess this might be a common problem when landing extraordinarily hard on the front wheel or all wheels for that matter.
    I will attempt to JB weld fill the engine with oil
    to see how it runs then I’ll make a decision to change it or not.
    The pan its self its not expensive varying in price from $190 to $330
    However its installation its different story.
    Perhaps a professional here can weigh in as to the cost or hours involved in R&R
    Thanks
  11. May 31, 2020 at 10:59 AM
    johncus
    johncus [OP] Member
    john
    I am also thinking about removing the engine to do the upper Oil tank replacement.
    Anyone here done an 4.0 4x4 engine R&R ?
  12. Sep 28, 2021 at 3:30 PM
    Rollin-slow
    Rollin-slow Member
    Blue
    San Mateo
    ‘15 DCLB
    Hey John,
    Any update on how you addressed the leak?
    I have a similar problem and intend to try and patch it first to see how it goes.
