upper radiator hose 5VZ-FE V6
Discussion in 'Technical Chat' started by Nowhereman04, Feb 22, 2010.
  1. Feb 22, 2010 at 3:46 PM
    Nowhereman04
    Nowhereman04 [OP] Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    how hard is it change the upper radiator hose on the 5VZ-FE V6? it looks pretty simple. but then again, i've had some "easy" looking projects that turned into nightmares. looks like all you need is a new hose and a pair of channel locks.
    any secrets? how much coolent will i lose when i disconnect the hose? kinda want to do it myself to save a few bucks.
  2. Feb 22, 2010 at 3:48 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You will lose very little fluid. You could replace the missing fluid with water and not have an issue. Just do it!!!
  3. Feb 22, 2010 at 3:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    x2......let the radiator cool down a tad then take the clamps and hose off. i recommend replacing the clamps with screw type clamps.....dont trust them spring clamps too much.
  4. Feb 22, 2010 at 6:29 PM
    Nowhereman04
    Tar Hill Blue NC
    thanks for the input guys. i just didn't know what the risk was of causing an air lock in the cooling system and leading to a bigger problem.
