Upper radiator hose leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bambigular, May 25, 2009.
  1. May 25, 2009 at 9:11 PM
    Bambigular
    Bambigular [OP] Well-Known Member
    Corona, Ca
    04 Double Cab SR5
    I have had this problem for a while, and search the forums but no answer. I have 04 DC V6, the leak is coming from the upper radiator hose right above the timing belt cover. The coolant accumulates to a small puddle. I just had all the belts, hoses, and water pump replaced a few months ago, it was happening before the change. Any help will be appreciated.
  2. May 25, 2009 at 9:17 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    hmm..thats a good one. Mine started leaking, so i replaced the upper hose and it went away. You sure your goose neck(plastic thing where the upper hose is attatched to) isnt cracked? The clamp could be bad also..Did who ever you have do it, replace the hose clamp?
  3. May 25, 2009 at 9:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Could be a crack at the connection..or the water pump.
  4. May 25, 2009 at 9:23 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
  5. May 25, 2009 at 9:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. May 25, 2009 at 9:28 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
  7. May 26, 2009 at 10:04 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Like said above, replace the clamp with a screw type, the spring style calmps are known to fail....
  8. May 26, 2009 at 3:37 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    ive still got the original on mine after 129,000 miles:confused:
  9. May 26, 2009 at 11:13 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    I replaced the hose clamp with the screw clamp when I changed the water pump, timing belt a few months ago. I'll take a picture and post it up tomorrow. Thanks tho
  10. May 27, 2009 at 4:15 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    here's the picture, does any one know what's going on?
  11. May 27, 2009 at 4:22 PM
    2toys
    2toys Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    is that a bulge near the bottom at the clamp? might be time to replace the hose and inspect the part where the hose attaches for cracks. I hate to just throw parts at a problem, but there's not much else it could be.
  12. May 27, 2009 at 4:30 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    Its a new hoses and it was happening before I put the new hose on.
  13. May 27, 2009 at 4:52 PM
    2toys
    Los Angeles
    did you inspect the flange the hose connects to for cracks? maybe leaking gasket at the bolt on area of flange (if applicable)?
    (these kind of leaks drive me CRAZY!!)
  14. May 27, 2009 at 8:50 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    loose that hose clamp, and get the regular spring style...Almost 100% that its leaking under that clamp
  15. May 27, 2009 at 9:21 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    Had a spring clamp before the screw clamp and it leaked.
  16. May 27, 2009 at 11:09 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    maybe a lower intake manifold leak?
