Uprgrading to rear lockers..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by azmikeymike, Jan 23, 2011.
  1. Jan 23, 2011 at 8:57 AM
    azmikeymike
    azmikeymike [OP] Member
    mike
    Phoenix
    06 TAcoma, 4x4
    Cold air, dual side out flowmaster Cat back, throttle body spacer, 3in body lift,
    I am thinkin about upgrading my rear diff to auto-lockers. Anyone have insight on the idea?
  2. Jan 23, 2011 at 9:06 AM
    xGManx
    xGManx Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    like an e locker or air locker?
  3. Jan 23, 2011 at 9:16 AM
    Natetroknot
    Natetroknot Def Leppard Sucks!
    Nate
    Dubuque, IA
    '11 Black Access Cab
    Billy's @ .85, 1.5 Progressive AAL, Leer 100xl, BFG KO2's
    I installed a powertrax locker in my open diff when I had a Jeep. Dana 35 axle. It wasn't a hard job b/c you didn't have to mess with setting preload and backlash, just removed c-clips on axle shafts enough to slide axles out of diff, replace side and spider gears with powertrax unit, and re-assemble.
    A removable third member on the Yota axles would be nice, but I have no idea if installation of a powertrax (or similar) would be the same beyond that. If it is, I recommend going for it.
    EDIT: pretty sure any locker that's electric and/or pneumatic replaces the entire diff (like Detroits, ARB, etc) and therefore would require sufficient knowledge and equipment to install.
  4. Jan 23, 2011 at 9:16 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I just bought a lock right no-slip... you have to have an open diff to run it though (ie. no LSD or locker) They seem pretty good for what i am wanting it for and ive heard good things from people that have ran them.
  5. Jan 23, 2011 at 9:17 AM
    cc350
    cc350 Retired Member
  6. Jan 23, 2011 at 9:17 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    What insight is there to have? The pros and cons are well documented, there are options available for purchase. Either do it or don't.
    Personally, I'd rather have selectable.
  7. Jan 23, 2011 at 9:18 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    You beat me to it :p
  8. Jan 23, 2011 at 9:28 AM
    Natetroknot
    Nate
    Dubuque, IA
    Lock-rights....I couldn't remember the name of em but same thing as the powertrax. Once in a while you'll prolly hear that sucker clunk pretty good but I never had a problem otherwise. Made a huge difference wheeling and was a lot of fun in the snow, since you lose the rudder effect the ass end will go wherever you point it!
    Good purchase, good luck with the install!
  9. Jan 23, 2011 at 9:35 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Thanks bud, im looking forward to it, i hate doglegging everywhere! Ill be installing as soon as i get home in Feb
  10. Jan 23, 2011 at 9:59 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Only selectable option is ARB. ARB costs $800, ARB compressor $200, installation $200-$300.
    As opposed to Powertrax which costs $300 and CAN be installed in your driveway.
    It all depends how much you can spend. Yes ARB is bad ass superior locker but not everyone has $1300 to drop ;)
  11. Jan 23, 2011 at 10:16 AM
    jandrews
    I would argue they should save until they do. But then, I have a hard time settling. Also, it's worth noting that if you go to air locker, you get OBA in the deal as well.
    Also, selectable locker is doable on the cheap by finding an e-locked third member either online, or at a junkyard, and wiring that thing on up. A little more install time/labor, but probably less costly than even the auto-locker in pure dollars.
  12. Jan 23, 2011 at 10:27 AM
    05RedTaco
    Tony
    Scottsdale
    Selectable locker fits into 8" axle, all non e-locker toyota axles are 8'4". yes its possible to fit in the e-locker 3rd member, BUT it requires modifyin the inside of the axle housing. Much easier routs is to get a whole 8" e-locker axle and swap that...
  13. Jan 23, 2011 at 10:36 AM
    jandrews
    Either or...axle or pumpkin...they would both work.
    But yes, that's my point...
