Upset... advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JanBoothius, Sep 28, 2010.
  1. Sep 28, 2010 at 12:17 PM
    JanBoothius
    JanBoothius [OP] Taco abuse specialist
    Jan (Pronounced Yon)
    Salt Lake City, UT/Upstate New York
    '10 TRD Off Road Access Cab, 6 speed
    OME lift, 886 coils, Dakars w/AAL ARB front bumper, Warn M8000 winch Toyo Open Country MT 285/75R17 (34) Leer 180CC cap etc etc etc $
    So, I was just driving my Tacoma, cruise control set at 75, and I accelerated to 80 in order to get around someone and get off at an exit, and as I was slowing back down and on the exit ramp, I shifted (please note my truck is a manual) from 6th to neutral, and as the truck was decelerating from 80 (still above 75) there was no load on the transmission, and I did not depress the clutch when I shifted (a bad habit, yes).
    I forgot cruise control was still on and set. Next thing I know, the truck was banging off the redline, I promptly hit the brakes and clutch, which disabled the cruise control setting of 75.
    It was redlining for only a second at most, but it the damage was done. Now, when I punch the gas, before the engine gains any revs, there is a slight clunk from the engine, this is more noticeable when in neutral, but also present when in gear.
    All the other manual vehicles I have driven with cruise control had a function/sensor that disabled previous cruise control setting when the transmission is taken out of gear, even if the clutch was not depressed.
    I foolishly assumed the Tacoma would be the same, especially with all the "acceleration" rumors. There must be a TSB for this? How do I find out? I am upset, my truck seems to have gained some sort of damage, and I don't believe this should have happened.
    The dealer I purchased it from said all the TSB's are performed before they put it on the lot for sale.. I'm starting to think that was bullshit.
    Please help, she barely has 6,000 miles on her, and I have never brought the RPM's anywhere close to the redline, and never planned on it.
    Another thing to note, I am 2,000+ miles away from the dealer I purchased it at. (Bought in NY, now I'm in UT)
    Does anyone else hear a slight clunk from the engine (not the transmission, I might add) when the throttle is blipped?
    Thank you very much for your help!
    -Jan
  2. Sep 28, 2010 at 12:21 PM
    JanBoothius
    There is a new and worrying noise that was never present until this happened. Did you read the whole post?
  3. Sep 28, 2010 at 12:23 PM
    8th sin
    8th sin Swollen Member
    Tampa, FL
    2015 DCLB 4x4 Sport
    Llumar CTX Tint, Grillcraft MX Upper, Pro Comp Rockwell 5034 17x8.5, Nitto Terra Grappler G2 LT285/70/17, Icon Stage III
    Hitting the rev limiter *should* not break anything...that's what it's there for. You can take it to any dealer for warranty service, and it should be covered.
    But I wouldn't mention you shifted it without using the clutch
  4. Sep 28, 2010 at 12:25 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    Well one quick check...does your rear have the 3-leaf or 4-leaf pack? Yea I call bs on the dealer as well. Sorry to hear about your incident though.
  5. Sep 28, 2010 at 12:26 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Take it to the dealer near you. It's under warranty, you don't have to go back to the same dealer you bought it at, your warranty covers you at any toyota dealer.
  6. Sep 28, 2010 at 12:28 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Jan I have a question and a comment ...... and I am not being a smartass about the question.
    Why would you put it in neutral exiting the highway? Do you normally do this?
    As far as the service. You can take it to any dealership for any other repair or service. It does not need to be the dealership you purchased the truck from.
    Best of luck.
  7. Sep 28, 2010 at 12:29 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If I had a new worrisome noise at 6000 miles, I'd take it to the local dealer (no worries about finding the out-of-state dealer I bought from) and describe the symptoms.
    No need to get into details about how it happened/what led up to it.
    You: "truck has worrisome clunking noise when blipping the throttle from idle."
    Service writer: "How long has it been happening?"
    You: "about a week."
    Service writer: "I'll have a mechanic check it out."
  8. Sep 28, 2010 at 12:30 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    I'm in agreement here. If something unexpected or stupid happens, you're going to be looking for problems and are likely to notice things that were there all along and see them as new issues.
  9. Sep 28, 2010 at 12:43 PM
    Twiget
    Twiget Proud to be Awesome
    America's Vancouver
    654, 6 Cylinders, 5 Speeds, 4 wheel drive
    Alpine Headunit, Soft Tonneau Cover, CAI
    In my experience cruise control is cut off in one of 3 circumstances, the clutch pedal is depressed, the brake pedal is depressed or the cruise control is turned off manually. Granted, I've not driven every model car out there, but I've never seen one that has a function like you describe.
    I do it as a hypermilling technique to help with gas mileage. Take the truck out of gear and let it coast to a stop, or even slow down to a lower speed limit. Saves on brake wear and helps with mileage.
  10. Sep 28, 2010 at 12:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    So cutting thru all the fat here, whats the new & worrysome noise you hear
  11. Sep 28, 2010 at 12:49 PM
    JanBoothius
    I usually shift into neutral whenever I am slowing down over a longer distance, I drive as efficiently as possible, and this helps a lot.
    3 leaf pack, yep, bullshit.
    I most certainly did not hear this clunk before, and I monitor this truck as if I am monitoring my own life. Believe me, the noise was NOT there before.
    Good advice; I wasn't planning on telling them the 'story' regardless.
    Where can I find info about TSB's? I want to find out whether there is a TSB that should have addressed the issue of the cruise control not being partially disabled when the truck is brought out of gear.
    Thanks for all the input, I really appreciate it.
  12. Sep 28, 2010 at 12:51 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Wouldn't just backing off the gas pedal and letting the engine break do about the same? With my AT I ease off the gas while coming up to a stop sign or red light but I am still in gear and have control over my vehicle.
    Anyways ... we are getting off topic here .... cheers.
  13. Sep 28, 2010 at 12:54 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    I know the first gen manuals have a clutch switch cutoff. Mine works. I can't imagine that sencond gens don't. It should state it in the owner's manual.
    If this is the case, yours would be faulty.
  14. Sep 28, 2010 at 12:55 PM
    JanBoothius
    My previous Subaru did this, as well as my parents Saab. I know that not all vehicles have this safety feature built in, but I assumed on newer cars (even a truck), it would be a standard safety feature.
    Exactly.
    When I blip the throttle, an extremely short amount of time before the RPM's increase, there is a clunk. This happens whether I am in gear, or in neutral. I already posted this info.
    I am going to drive the truck to class now, I will report back afterwards, and see if there are any changes... However it happened on the way to my previous class, and was still there on the drive home.
  15. Sep 28, 2010 at 12:56 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Toyotaowners.com go there register & see what pops up, pretty accurate, I registered my 2000 & they even shot me back a recall about my trailer harness, asked me when I was gonna bring it in, not to mention all tsb's associated with my truck records & service records really surprised me...:cool:
    Actually I think its www.toyotaownersonline.com
  16. Sep 28, 2010 at 12:58 PM
    JanBoothius
    The clutch cutoff switch is functional.. My bad habits ARE to blame, as I made an assumption based on the previous manual transmission vehicles I have driven, as I shifted from 6th to neutral when there was not load on the drivetrain, and forgot cruise control was on, all the while subconsciously assuming that shifting without depressing the clutch would disable the cruise control, as it did in previous vehicles... again, I have already stated all this info in previous posts.
  17. Sep 28, 2010 at 1:16 PM
    Twiget
    America's Vancouver
    Here is a link to some hypermiling FAQ's: click. I've dabbled with hypermiling for awhile, but when I got my taco and found that around town mileage was ~16mpg (where I do most of my driving), I started to get serious about it. I've increased my mileage to ~19mpg, it is a takes a lot of situational awareness and can be a PITA to get good at, but I think it's worth it.
    News to me. IMO, stuff like that just encourages bad driving technique. :D
  18. Sep 28, 2010 at 3:25 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    I see no reason why you would shit yourself when exiting the interstate. That is definitely a bad habit.
  19. Sep 28, 2010 at 3:46 PM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Okay .... I am going to play the role of the Devil's Advocate ..... bear with me Larry :D.
    Below are parts of a few posts with their writer regarding this thread:
    - "But I wouldn't mention you shifted it without using the clutch." - (8th sin)
    - "No need to get into details about how it happened/what led up to it." (bjmoose)
    - "Good advice; I wasn't planning on telling them the 'story' regardless." (OP)
    Now, what is the #1 concern with consumers, particularly auto buyers? My guess ..... auto dealerships.
    Most complaints range from overchaging of services to performing unnecessary repairs. From faulty testing to having to bring vehicle in time and again to fix problems.
    With these comments and suggestions y'all are posting kind of puts the shoe on the other foot. Doesn't it?
  20. Sep 28, 2010 at 4:05 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    My bad, your post had a lot of words, I missed a couple.
