Upside down oil filter????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SNThorsen, Jul 7, 2011.
  1. Jul 7, 2011 at 7:49 PM
    SNThorsen
    SNThorsen [OP] Well-Known Member
    Shelby
    Mobile, AL
    white 09 TRD Sport
    Sprayed black wheels/ bed lights/ fog light mod +yellow lens/ reverse light mod(changed to fog lights)/ 5100s x4 / under the hood lights/ driver seat flashlight holder/ bed fire ext./ next up will be some tires not sure type yet.
    I dont know about the rest, but the 09 sport has the upside down oil filter on the top front of engine. Thoes of you who do your own oil change, how do you take the filter off with out pouring the oil all over the fan belts? is there a trick i am not getting? or is the oil supposed to drain back down and mine is not doing that? I have done a few oil changes and every time it makes a mess all over the place. Let me know what you guys do. Thanks.
  2. Jul 7, 2011 at 7:50 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    theres a drain plug underneath your oil filter, on the metal lip. just get a piece of hose and hook it up...drains real easy
  3. Jul 7, 2011 at 7:50 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    look in the mods and tutorials
  4. Jul 7, 2011 at 7:52 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Do you think only the Sport has this?
    I solve the problem by having Toyota Technicians at my dealer do the change (and check over the truck) every 3-5 k miles... Nothing breaks on a Tacoma... maybe because of this, but it is a cheap way to keep the truck in top shape and documented for any warantee stuff if that ever happens. About $35 every 4,000 miles is CHEAP, in my opinion.
  5. Jul 7, 2011 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  6. Jul 7, 2011 at 8:02 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Prop an empty powerade bottle under that lil spout & no mess no fuss when done pour into pan.
  7. Jul 7, 2011 at 9:59 PM
    JKD
    JKD Well-Known Member
    It's the perfect filter location, and the drain cup has worked fine every time.
    Having changed filters on plenty of vehicles where jack stands and/or an extra elbow are required, I am overjoyed to have the filter right there in front of my face when changing the oil.
    Bend up an old coat hanger to hold a bottle under the little drain spout (and don't forget to put the rubber cap back on the spout when finished). Piece of cake.
  8. Oct 25, 2011 at 11:10 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    I can't believe nobody has talked about the "pick trick".
    (This trick applies to filters without a drainback valve.)
    1. Take a pick or sharp pointy object and punch a hole on the top of the oil filter.
    2. Wait a minute or so for the oil in the filter to drain into the pan.
    3. Continue with your oil change procedure.
    I hope I'm not sounding like an ass cause somebody else already said this...
  9. Oct 26, 2011 at 2:45 AM
    lrak
    lrak Well-Known Member
    Do these even exist anymore? If you could find one would you want to use it on an engine where the filter is mounted upside down?
  10. Oct 26, 2011 at 3:17 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    /\ THIS!!!
    An empty 1 quart oil bottle works just as well. Pull off the rubber nipple, and wedge the bottle down in there. Screw off the oil filter and watch the magic happen!
  11. Oct 26, 2011 at 4:28 AM
    Yoterman
    Yoterman Active Member
    Central KY
    97 ext. cab 2.7L 4wd 5spd
    I think it's a great idea! I've only had my truck for a couple months, but I can't wait to change the oil when the time comes. So much easier than the previous models.
  12. Oct 26, 2011 at 5:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I do this except usually with a Poland Spring bottle, they're narrow and very flexible since the plastic is so thin.
  13. Oct 26, 2011 at 5:50 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    i just hold a dixie cup or whatever you guys call those red plastic cups(solo) under the little spout and loosen the filter till the oil starts to drain out into the cup. Once it's done i replace the little cap and wipe off the oil cooler where the filter gasket seals. Then lube the new filter gasket with some fresh oil and install. Simples
  14. Oct 26, 2011 at 11:04 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Cheap until they leave the oil catch can in your truck, and your fan sprays oil all over the engine compartment................ Not to mention not even doing the work. Piece of mind doing it yourself and right is better then having a person being paid a bit over minimum wage do a shit job.
  15. Oct 26, 2011 at 11:13 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    When I'm done with my beer, I put the empty can underneath the drain spout, and continue with the oil change.
  16. Oct 26, 2011 at 11:37 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Judging by your posts here on TW I assumed you were the type that did your own oil changes...kinda suprised me that you'd have a dealership do it. You do know you can do the documenting yourself and be well within the warrenty right? :confused:
  17. Oct 26, 2011 at 12:15 PM
    Goldstar225
    Goldstar225 Well-Known Member
    Tom
    Central Arkansas
    2011 Pre-runner SR5 4X2
    The location for the filter was one of my favorite things about the truck (and showed the thought that went into the design). I don't know which I dislike most, filters horizontally on the block or open end up on the bottom. It seems I was always dribbling some oil with those.
  18. Oct 26, 2011 at 12:23 PM
    Pugga
    Massachusetts
    I had the stealership do my oil changes til I hit 36k miles. No need to ever bring documentation into question while under warranty. Plus they were offering $10 oil changes which was cheaper than I could buy the supplies myself.
  19. Oct 26, 2011 at 1:44 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I just turn my truck upside down, unscrew the filter, let it drain. Screw on the new filter and turn the truck right side up again. Geez!
  20. Oct 26, 2011 at 1:47 PM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    ^^^^^ This is what I do every time as works excellent
