UpTop TRUSS rack and Diamondback HD experiment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CttAznRanger, Sep 30, 2020.
  1. Sep 30, 2020 at 9:50 AM
    CttAznRanger
    CttAznRanger [OP] Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Oh? I might hit you up for something then. Those side pieces that are on the TRUSS would make it a little short for my taste. So I would probably space out the bars and custom make one to go across them.
  2. Sep 30, 2020 at 9:51 AM
    CttAznRanger
    Brandon
    Boston, MA
    On that note, @upTOPoverland is the flagship truck the full height rack?
  3. Sep 30, 2020 at 9:56 AM
    CttAznRanger
    Brandon
    Boston, MA
    Additionally, if I were to space them out to sit in the diamondback more evenly, would that still allow for the EX to be bolted up correctly?
  4. Sep 30, 2020 at 9:59 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Let me know. I know good welders but my main guy is slammed with work at his main job
  5. Sep 30, 2020 at 10:06 AM
    CttAznRanger
    Brandon
    Boston, MA
    Ok, so now I'm getting some crazy ideas... I might have to make a mock version out of wood to see if I can do 4 bars instead of the standard 3....
    This way I can mount things to each set of two, and not have to unbolt anything to open up the cover... But a project for another day. In the meantime, ideas ideas ideas.
  6. Sep 30, 2020 at 10:15 AM
    upTOPoverland
    upTOPoverland Well-Known Member
    Drew
    2019 Tacoma TRD OR
    upTOP All the Things!
    All upTOP trucks run full height. They are MAS COOL
  7. Sep 30, 2020 at 10:16 AM
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    No Likely, our eX is set up to work with our leg spacing
  8. Sep 30, 2020 at 10:22 AM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Have you considered two modifications to your plan?
    1. Order a custom rack without the flaps. (so the rack sits flat on the cover).
    2. Front Runner rails. (the flat rack can then mount to the Front Runner Rails).
    The rail channels shown bolt to the Diamonback. The legs of the rack bolt to the groove in the rail channel.
  9. Sep 30, 2020 at 10:23 AM
    CttAznRanger
    Brandon
    Boston, MA
    What is the leg spacing you guys are working with? I'll have to measure out and see if I have the overall length to do that.
    If you could also get me the overall length of the long bed EX as well spacing from one end to the other of the load bars.
  10. Sep 30, 2020 at 10:25 AM
    CttAznRanger
    Brandon
    Boston, MA
    1) Yes, I have. Only problem is that they are running pretty much at capacity so I don't believe they will have time for custom stuff until a bit later. Drew also pointed out the Retrax version, so that will work.
    2) Front Runner rails are too short for my liking. As clean and simple as they are, it would block my rear window a bit, which I am not entirely fond of.
  11. Sep 30, 2020 at 10:29 AM
    The_Devil
    E
    I added a photo. What I meant to suggest was the Front Runner channel rail that runs down the length of the truck, and allows you to add a rack of your choice.
  12. Sep 30, 2020 at 10:41 AM
    CttAznRanger
    Brandon
    Boston, MA
    Yeah, that makes sense. The only question I have for that is, does anybody make a full height rack that fits in the Front Runner channels?
  13. Sep 30, 2020 at 10:44 AM
    The_Devil
    E
    So, when I looked at your preferred rack vendor, it occurred to me that with the side plates gone, and a flat bottom, all that would be required was a drilled hole in the bottom of the rack plate that normally sits on the plastic bed rail covers.
    I will look around and see.
    By the way, your idea of four rails (two per half of the Diamonback) would theoretically allow you to open either half.
  14. Sep 30, 2020 at 10:49 AM
    CttAznRanger
    Brandon
    Boston, MA
    Right, the Retrax version already has holes pre-drilled through the bottom to attach to a Retrax cover. I would use those to drill holes through the diamondback cover and bolt it directly on there.
    Correct, the only concern would be that, upon opening the cover, would the two center crossmembers collide with each other. I would have to mock something up for that to make sure.
  15. Sep 30, 2020 at 10:51 AM
    #35
    CttAznRanger
    Brandon
    Boston, MA
    If it does work, I think the best bet would be to get the TRUSS AFS RETRAX version.
  16. Sep 30, 2020 at 10:53 AM
    #36
    The_Devil
    E
    So, this is the 18" KBvoodoo available with optional tonneau brackets. LINK
    Also included some photos of the KBvoodo brackets.
    They also have a 22" version.
  17. Sep 30, 2020 at 10:55 AM
    #37
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    didn't his rack break on some trail? he had to ratchet strap the tent down so he could get it home?
  18. Sep 30, 2020 at 10:57 AM
    #38
    The_Devil
    E
    So, I suggested two different ideas.
    First was the Front Runner channel rails, which would require drilling and bolting those rails. The beauty here is that these channel rails provide endless mount points for anything including a rack. The rack does not need new holes in the diamondback.
    The legs of the rack mount to the channel , and therefore can be moved along the channel without requiring custom holes.
    The second suggestion was simply to look at KBvoodoo who has a unique bracket for use with Tonneaus like the Diamonback.
  19. Sep 30, 2020 at 11:01 AM
    #39
    CttAznRanger
    Brandon
    Boston, MA
    Yup, I did see that one a while back. I only don't like it because I can't open my cover while their rack is attached.
    Did it? But if it was the rack and not the diamondback, I think the TRUSS is stronger, so it should be ok.
    Yes, agreed, those two ideas would work, depending on who is looking at them. Front Runner rails would be too short imo, for my purposes. And KBVoodoo doesn't allow it to open while the rack is on there.
  20. Sep 30, 2020 at 12:47 PM
    #40
    upTOPoverland
    Drew
    2019 Tacoma TRD OR
    It wasn't an upTOP :thumbsup:
