URD 2.55" Pulley and Meth dyno
Discussion in 'Performance and Tuning' started by Eggbert, Sep 5, 2014.
  1. Sep 5, 2014 at 11:30 PM
    Eggbert
    Eggbert [OP] Well-Known Member
    PA
    '14 dcsb TRD OR Supercharged
    TRD Supercharger, MBRP DualCatback, DT Shortie Headers, Regeared with 4.56 ECGS 3rd and Clamshell, URD 2.55" Stealth pulley, AEM Methanol 5 gallon kit, URD Perf Thermostat, NST Lightweight crank pulley, URD 61lb injectors, Mishimoto Oil Catch Can, URD Fuel Pump upgrade, AEM Boost and Wideband gauges, OEM FPR Mod, RBP Black Exhaust Tips, Icon Stage 6, Fuel Octane wheels, Nitto Terra Grapplers 285/70/r17, Color match rear bumper, Color match hood with skewp, Color match grill, Color match valance, Derped grill emblem, Derped Tuffbar bullbar, OEM Skidplate, AVS Ventvisors, Bodyside Moldings, RBP RX3 nerf bars, Color Match Bushwacker Pocket Flares/Rivets, Undercover LE Tonneau, Katzkin heated leather, Bel Stir-Plus Radar, Sprint Booster, Dynamat/Hushpad, Polk dxi691 - front, Polk dx1651 - rear, Alpine KTP-445U Power Pack, Front tint 35 percent, Weathertech front mats, Smoked tail lights, LED DRLs, Coupe TRD Battery tie-down, Coupe TRD CAI Cover
    Finally got dyno tuned after 2.55" URD pulley and AEM meth injector install.
    Got about +17hp and +17tq over the 2.7" pulley. Guys at RT Tuning did a great job with install and tune - reversed the FPR mod and went with the URD 61lb injectors instead.
    Truck pulls much smoother through entire RPM range (no more hesitating and surging). For you guys in the Philly area, I'd highly recommend this shop.
    I think I've pretty much maxed out the TRD S/C route except for swapping my shorty headers for LTs (don't want to lose low end torque tho) and swapping OEM Y-Pipe for the URD one.
    Dyno vid : Dyno graph:
  2. Sep 6, 2014 at 1:16 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    Nice! I bet that's a fun ride.
  3. Sep 6, 2014 at 1:28 PM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    So do you have the reflash or is your's tuned just with map ecu?
  4. Sep 6, 2014 at 9:14 PM
    Eggbert
    PA
    Still have the TRD reflash with MAPECU3 piggybacking. Would really like to upgrade to a UCON but no harnesses for 2009+ available:(
  5. Sep 6, 2014 at 9:17 PM
    Eggbert
    PA
    Can't believe the mileage improvement with the new tune and reversing the FPR mod. Have gone from ~14.5 mpg to ~19mpg
    The TRD tune is really way too rich
  6. Sep 7, 2014 at 2:43 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    what was the cost on the piggyback and what can it all do
  7. Sep 7, 2014 at 7:44 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Nice!! What's your elevation? Hp seems low for that pulley ratio? Now that you have the 668 injectors; you could try e85 tune with a 7th injector. High octane and e85 would cool down those rotors pretty well... What percentage water meth you spraying? What size nozzle? You using a boost controller?; at what psi you tuned for spray?
  8. Sep 8, 2014 at 6:13 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    how much increase did u notice from just the water meth? or did u do a before and after run?
  9. Sep 8, 2014 at 9:00 AM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    That dyno graph you posted looked weird until I realized it was a narrow window of only 4,200rpms to 5,500rpms. Do you have a full RPM range graph you can post?
  10. Sep 8, 2014 at 9:43 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    considering its an thats the best he can do. might be able to do a 3800 to redline pull if he goes again.
  11. Sep 8, 2014 at 9:52 AM
    Ostrichsak
    Jer
    I think you left out the most important word in this statement.
  12. Sep 8, 2014 at 9:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    FIFY.
  13. Sep 8, 2014 at 9:56 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
  14. Sep 8, 2014 at 9:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I looked through the F/I dyno thread recently. Comparing long tubes versus short, or even stock. Didn't see dyno's with long tubes where the "low end" was lost. Being a roots style, it instantly creates power as soon as you put the hammer down.
    Spec-U headers and the new Spec-U exhaust should only benefit you more.
  15. Sep 8, 2014 at 4:02 PM
    TRON
    I agree... Long tubes would probably help vs hurt for low end torque... Regardless, this new exhaust system is almost exactly like my custom set up. I do have high flow cats in my ypipe though. Once I move back to WNC they might just be removed. The sound is amazing
    I would like to see the full graph as well; especially torque numbers around 2000 rpms
  16. Sep 8, 2014 at 6:09 PM
    Eggbert
    PA
    Thanks! Elevation near sea level. HP does seem low, I was hoping for something at least 325HP. Also, the MAPECU3 is just not that great for tuning especially with the larger injectors.
    Here are the tuning notes:
    • Vehicle loaded onto Dynojet and secured for dyno tuning.
    • Vehicle operated under cruising and part throttle conditions and
    • mapping optimized under these conditions.
    • Vehicle operated at wide open throttle and fueling adjusted by
    • MAF voltage offset for optimum and safe power and air/fuel ratios.
    • Vehicle found to run very rich on initial dyno testing even when
    • pulling up to 1V from MAF signal. Adjusting MAF offset to
    • compensate for methanol and injector size would create an overly
    • aggressive ignition timing advance situation.
    • Tuner installed a smaller methanol injection nozzle and continued
    • tuning vehicle for optimum power.
    • Vehicle allowed to cool overnight and then cold start, cold
    • operation checked. All cold start conditions checked good.
    • Fuel trims +/-3%.
    Mixture is 49/51 Meth/H20. Set to 5psi threshold
  17. Sep 8, 2014 at 6:10 PM
    Eggbert
    PA
    LOL I thought the exact same thing! Have sent them a message and hope to have an expanded graph in the next few days
  18. Sep 8, 2014 at 6:11 PM
    Eggbert
    PA
    Cool thanks for the advice T and T. I'll have to hit Gadget up for some Spec-Us:D
  19. Sep 11, 2014 at 7:18 PM
    Eggbert
    PA
    Finally got the full dyno and they didn't lock in a gear so do you guys think I could have hit some higher numbers for HP if we removed the shifts?
  20. Sep 12, 2014 at 4:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I think I know why your numbers seem different. Your 4.56 gearing. I bet it takes off like bat out of hell though.
