URD 2.8" pulley installed
Discussion in 'Performance and Tuning' started by Detective_Dan, Jan 12, 2013.
  1. Aug 24, 2013 at 4:11 PM
    #41
    tank3105
    tank3105 Well-Known Member
    Houston
    13 baja T/X edition supercharged
    Supercharged.
    Correct, 30 minutes to cool and one can.
  2. Aug 24, 2013 at 9:54 PM
    #42
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Took you 30min to drain that puppy?
  3. Sep 2, 2013 at 3:29 PM
    #43
    Ostrichsak
    Jer
    For those that did this mod who do you remove the belt? Do you have to take the cooling fan out to access that tensioner arm or if I take off both of my skid plates can I access this from the bottom or ??
  4. Sep 2, 2013 at 3:31 PM
    #44
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I took my breaker bar and moved the tensioner bar from the top. Took a little working it, but required no removal of the fan assembly or anything like that.
  5. Sep 2, 2013 at 3:34 PM
    #45
    Ostrichsak
    Jer
    So you removed the entire assembly rather than just turning the arm clockwise to relieve tension from the belt?
  6. Sep 2, 2013 at 4:35 PM
    #46
    memario1214
    Colton
    Missoula, MT
    No, I simply turned the arm clockwise using a breaker bar to relieve tension from the belt. This did not require removal of any truck components.
  7. Sep 2, 2013 at 4:43 PM
    #47
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    If you don't have a skid plate, the tensioner is much easier from the bottom. At least I personally think it is lol
  8. Sep 2, 2013 at 4:45 PM
    #48
    Detective_Dan
    Colorado Springs
    Just FYI, I have a brand new in package oem blower belt from Toyota if anybody needs one. $35 from Toyota. $20 from me. Pm me if you want it
  9. Sep 2, 2013 at 7:14 PM
    #49
    Ostrichsak
    Jer
    The back of the fan clutch just barely clears the spot you would put the 1/2" drive into. I don't see how it can clear. Is there a divot or something in the fan clutch that I didn't see? Like if I turn it a few times there will be a spot that gives me better access to that? I see a lot of people talking about this in all the searches I did but nobody really mentions any details.
    I don't have a skid plate. I have two. :( I have the stock skid and then the optional TRD fanciful skid too. I'll have to remove both to access from the bottom and it seems that working on this myself will be a lot more difficult relieving tension from the bottom and then removing the belt up top. I can use something down there to hold it but I keep reading about people doing this from above and I still don't see how they make it seem so simple.
  10. Sep 2, 2013 at 8:22 PM
    #50
    memario1214
    Colton
    Missoula, MT
    Nothing special... the breaker bar I used doesn't have a ratchet function which may have made it easier for me to get it in there due to it being slimmer.
  11. Sep 2, 2013 at 8:48 PM
    #51
    Ostrichsak
    Jer
    Alright, I was using a 1/2" ratchet so I'll check out a 1/2" breaker bar as well as a 3/8" breaker w/a 1/2" adapter on the end. Something has got to work so knowing that you got it to work is inspiring me to try this method again. Others have said that you need to pull the skid plates off of the bottom and get at it all from down there (which I'm sure you can) but I was sure there had to be an easier way than that. Thanks for the help!
  12. Nov 25, 2014 at 4:26 PM
    #52
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Jason how's the new toy?
  13. Nov 25, 2014 at 5:06 PM
    #53
    Detective_Dan
    Colorado Springs
    New toy is in black Betty? Love it!
  14. Sep 21, 2015 at 11:27 AM
    #54
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Is it safe to do the 2.8 inch pulley without doing the fuel pump upgrade?
  15. Sep 21, 2015 at 11:42 AM
    #55
    Tacoma SS
    Denver
    I'm thinking about doing the 2.8 with an AFE CAI and Thorley shorty headers to go with my 3 inch catback. Any guesses on what I'd be looking at power wise?
  16. Sep 21, 2015 at 11:56 AM
    #56
    Tacoma SS
    Denver
    ... That's only like 30 horsepower more than stock. I thought I'd have way more power
  17. Sep 21, 2015 at 11:59 AM
    #57
    Tacoma SS
    Denver
    Oh nice, how much power do Tacoma's run at the wheels stock?
  18. Sep 21, 2015 at 12:00 PM
    #58
    stempsons
    stempsons Well-Known Member
    SW WA
    2015 Tacoma TRD O/R 4x4 DC
    TRD Supercharged, TRD Exhaust, TRD Bead Locks, OEM Audio +, Bilstein 6112's/5160's
    The dyno numbers are based on power at the wheels...so, 264 at the wheels is over 300 at the crank (assuming 10-15% drivetrain loss).
  19. Sep 21, 2015 at 12:01 PM
    #59
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    190 to 200 whp and 230 to 240 wtq.
